How to debug CrossEPG issues and get it working on OpenPLi 4
Results 1 to 12 of 12
    Top Poster weedman's Avatar
    Dec 2011
    By my computer
    Default How to debug CrossEPG issues and get it working on OpenPLi 4
    This is a guide to help you guys who are struggling to get CrossEPG working on OpenPLi 4. I've reinstalled and configured the same image many times and I've gotten CrossEPG working everytime, below i'll show you how.
    Install libcurl4 - This should fix all the issues
    It's actually just 1 library thats missing `libcurl4`, install it using:
    opkg install libcurl4
    You may need to reboot (although I don't think it's necessary).
    Go back to CrossEPG, make sure it's set to write to your HDD or USB, select Sky UK from the providers list and hit Download.. tada!
    Still not working?
    If it's still not working you'll have to do some debugging (It's actually quite easy), run the following command through telnet.
    init 4; sleep 4; enigma2;
    This will reboot your dreambox and you'll see all the debugging output logged to your console. Go back and try the CrossEPG download, when it fails keep an eye on the logging info and see what it says.
    This was how I debugged the `libcurl4` issue!
    Hopefully this helps all you guys having issues with CrossEPG, not sure about other images but this 100% works on OpenPLi 4.
    The debugging technique should aid you in tracking down any issues your having (relating to CrossEPG or anything else - It's extremely useful to see all the debugging when something goes wrong).
    - Thanks to those who deserve them, and none to those who don't...
    - DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
    - weedman
  2. The Following 4 Users Say Thank You to weedman For This Useful Post:
    gmb45 (7th March, 2015), martialdiego (1st August, 2015), Slots (6th February, 2016), sumfeen (10th January, 2016)
  3. #2
    Sep 2012
    hi
    do you have the ipk file and can i install it by USB to do the same thing as above
    Dec 2011
    By my computer
    Quote Originally Posted by elad View Post
    hi
    Yeah sure, find it the crossepg and libcurl4 attached below:
    enigma2-plugin-systemplugins-crossepg_0.8.1-r0_mipsel_openpli4.ipk.zip
    libcurl4_7.40.0-r0.0_mips32el.ipk.zip
    You can install it by unzipping & copying to your usb, traversing to your usb on your dreambox via telnet and then installing it using:
    opkg install libcurl4_7.40.0-r0.0_mips32el.ipk
    opkg install enigma2-plugin-systemplugins-crossepg_0.8.1-r0_mipsel_openpli4.ipk
    Reboot/Restart Enigma2
    Then simply setup crossepg on your TV (make sure it writes to a USB or Hard Drive), Select SKY UK 28.2 (It should have a tick), save your settings, hit download, and everything should work, If not you'll have to try and debug it yourself using the commands in my above post.
    Hope this helps!
    - weedman
  5. The Following 6 Users Say Thank You to weedman For This Useful Post:
    boydy67 (24th August, 2015), garp55 (8th December, 2015), jkewarns21 (13th December, 2016), martialdiego (1st August, 2015), tbabit (17th August, 2015)
  6. #4
    Nov 2015
    Upgrading libcurl4 from 7.37.1-r0 to 7.40.0-r0.0 on root.Configuring libcurl4.
    Collected errors:
    * satisfy_dependencies_for: Cannot satisfy the following dependencies for libcurl4:
    * libgmp10 (>= 6.0.0) * libgnutls28 (>= 3.3.12) * libc6 (>= 2.20) *
    * opkg_install_cmd: Cannot install package libcurl4.
    launching curl from command line:
    root@dm800:~# curl
    Aborted
    EDIT: i solved my issue with curl replacing the binary with the one found here http://files.lancethepants.com/Binar...0%28MIPSR1%29/
    CrossEPG 0.8.1 still not working
    root@dm800:~# /usr/crossepg/crossepg_downloader
    Aborted
    for now gone back to 0.7.0
    Dec 2011
    Thanks Weedman! Installing libcurl4 fixed my issue!
  8. #6
    Feb 2016
    Default Still now joy
    Quote Originally Posted by weedman View Post
    Hope this helps!
    Hi there , I'm not 100% how to telnet the files so i downloaded the ipk files , i put both on usb and they where excepted but still flicks straight from starting downloader to Loading data and finds nothing , could you possibly explain the next step , debugging i can follow instructions to telnet if thats the only way
    Peter
  9. #7
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by Slots View Post
    Peter
    To telnet your box, you're sending telnet commands from your PC to your Sat box, you can use the command prompt on a Windows PC or install a program called putty. Run putty and enter your Sat box's IP address + username & password then enter the telnet commands provided by weedman
  10. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    Johnner (6th February, 2016), Slots (6th February, 2016)
  11. #8
    Feb 2016
    Thanks martin and BIG thanks to the WEED MAN tried everything to get this working , just to say to anyone else the usb method didn't work for me either but a simple telnet via terminal on mac of -Code:opkg install libcurl4
    and BOOM a working EPG again , thanks again
  12. #9
    Feb 2016
    Mine has suddenly stopped working ? Can anyone help ? It goes through all the download -Parsing titles - saves date converts data etc but nothing in the programs guide all blank ? Tried swapping over the feeds at back of box but that didn't work 🤔🤔🤔🤔
    Help
    Peter
  13. #10
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    @slots, try deleting all the files in your crossepg folder and the EPG.dat on your USB drive. Then manually select crossepg to download.
  14. The Following User Says Thank You to martin035 For This Useful Post:
    toysoft (1st May, 2016)
  15. #11
    Aug 2016
    Hope this helps!
    where we put the ipk files /temp?
    and the exact code to install via telnet?
  16. #12
    Oct 2016
    Daft question can you expand on your "solve my issue" please? Where did you put that CURL file?
