salam
plz help code and safe2 rcd 210 panasonic
serier:014vwz5z1h00300787
1k0 035 156 a
I know very well that is not code in the eprom
But Sally programmed to read m32c
Is there another solution device
Thank you
salam
1k0 035 156 a
Thank you
"Stop racism, for we are all human beings"
http://www.digital-kaos.co.uk/forums...=1#post2143473
try solution without code for RCD500 maybe work on rcd210
[QUOTE=audiopoint;2490574] http://www.digital-kaos.co.uk/forums...=1#post2143473
try code sans solution verser RCD500 Fonctionne Peut-etre sur rcd210 [/ QUOTE] Ce lien ne fonctionne pas, il se ouvre une page avec l'erreur 404 o
posible reset couter
solved code 0025
I find the method to decode rcd210 panasonic
was ready two days
bogege (14th March, 2015), kappa1 (29th December, 2015), masterskay62 (14th March, 2015), murat332 (14th March, 2015), nelutzul40 (14th March, 2015), REZON (6th May, 2015), smoggy (14th March, 2015)
with which programer you read mcu
hi
i downlaod M16C flasher!
how to connect to the serial port on the MCU?
of which position is hidden cod?
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
Try this conection: http://help.martech.pl/?q=node/41
Decode Ghost (21st July, 2017), mcd76 (4th September, 2015), skens (3rd September, 2015)
hi
M16C flasher
connect to the direct serial port DB9 or DB25 LTP on the MCU!
not need interface?
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
You need interface of course.In picture is the martech adaptor DB25 not direct LTP port.This adaptor conect to the martech box.And martech read this m32c.
Also i tried with rs232 interface but not conect to this M32c, only conect to RCD500 m32c flash.Maybe somebody has a solution.
Also have solution to loked the counter but in this way takes more time to find code.
clydey (8th September, 2015), Decode Ghost (21st July, 2017), mcd76 (4th September, 2015)
hi
ihttp://www.m16c-flasher.de/
please read
There is no extra hardware required. The only thing you need is a serial cable between pc and microcontroller...
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
XJTAG (13th December, 2019)
Yes !You are right but it can read only M30833 from rcd500 panasonic.For rcd210 you must read M30879 which can not support this flasher.
skens (5th September, 2015)
These are connections
Hello.
Thanks for aswering.
Acording to the picture attached how should be the correspondent connections made?
regards
