Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    sonices's Avatar
    You have it on picture all
    CNVSS to Vcc is important
    It can read only M30833 but not M30879, as attilaa0 said
  2. #17
    Hello Man.
    Thanks for comment. I need to read m30833 from rcd500 mp3...
    i tested lots of different ways to comunicate but all unsuccesseful.
    Attached are some info that i have been reading, especially in renesas and some foruns.
    I changed the max232, reviewed all the interface adapter, changed operating system from xp to w98 but still not getting comunication...
    i am about to give up..... Help ...
    Edit: should i dessolder mcu from board and then try to read it?
    regards
    Last edited by tintin2005; 21st July, 2017 at 01:28 AM. Reason: New question and new pdf
  3. #18
    sonices's Avatar
    Dont give up so easy
  4. The Following 3 Users Say Thank You to sonices For This Useful Post:
    Decode Ghost (21st July, 2017), ilen (21st July, 2017), nelutzul40 (21st July, 2017)
  5. #19
    Hello sonices!
    Uau Man! You did it....! i have not seen the flasher version you have...
    Share connections please. if possible a picture.
    thank you
    Last edited by tintin2005; 21st July, 2017 at 01:06 PM. Reason: You did not ...I did it...bahhh
  6. #20
    sonices's Avatar
  7. The Following 3 Users Say Thank You to sonices For This Useful Post:
    Decode Ghost (21st July, 2017), nigrou (22nd July, 2017), tintin2005 (22nd July, 2017)
  8. #21
    Hello.
    As i did not gave up... here i am.... thank you for your help.
    Attached is the Dump from m30833 finnaly....
    Code please....
    regards
    tintin2005
  9. #22
    Decode Ghost's Avatar
    Aug 2015
    Quote Originally Posted by tintin2005 View Post
    Hello.
    Code please....
    regards
    tintin2005
    Try..............0070
  10. The Following 5 Users Say Thank You to Decode Ghost For This Useful Post:
    Albert G (22nd July, 2017), masterskay62 (22nd July, 2017), sanixmen (22nd July, 2017), smoggy (22nd July, 2017), sonices (22nd July, 2017)
  11. #23
    sonices's Avatar
    tintin2005 nice to hear it works
  12. The Following 2 Users Say Thank You to sonices For This Useful Post:
    Decode Ghost (22nd July, 2017), tintin2005 (22nd July, 2017)
  13. #24
    Hi!
    Code works.... big thanks.
    For me wasn?t enought the "text" schematic from http://www.m16c-flasher.de/ .
    regards
  14. #25
    carradio2001's Avatar
    France
    Hi !
    What about ID ? I get this message after Connect, when try to READ
    Carradio2001.
  15. #26
    sonices's Avatar
    What cpu you are trying to read?
  16. The Following User Says Thank You to sonices For This Useful Post:
    Decode Ghost (31st July, 2017)
  17. #27
    Quote Originally Posted by carradio2001 View Post
    Hi !
    Carradio2001.
    I have same error ,MCU is Renesas M30879
  18. #28
    Apr 2016
    Quote Originally Posted by sk760 View Post
    i have same error, with RCD210 MCU M32M30879 , the mcu is protected
    The microcontroller is protected by a 7 byte ID. Without the correct ID, it is not possible to read,
    write or erase the flash memory.
    The NON-PROFIT version of the M16C-Flasher only writes the ID 0x00 0x00 0x00 0x00 0x00
    0x00 0x00, so there is no protection.
    You have also the option to log all used IDs into a file (ID.LOG)
    By default the M16C-Flasher uses the last working ID. This is useful under most conditions.
    But if you are working at different devices with different IDs, you should select 'Extract ID from
    File
