Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
  1. #16
    speedy100's Avatar
    Athens
    Hi again,
    I have tried various settings in the driver but no luck.
    i also tested with 1260 cable but it does exactly the same thing. It sees the com port it selects the model car but does not show any ECU Module etc.
    Here I attach a screen capture of the problem.
    Any ideas please???
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  2. #17
    electronistul21's Avatar
    Nov 2011
    galati,romania
    you not instaling and data base for ddt.copy data base in C: ddt2000 data folder.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  3. The Following User Says Thank You to electronistul21 For This Useful Post:
    speedy100 (29th July, 2015)
  4. #18
    speedy100's Avatar
    Athens
    Default DDT2000 problem
    Quote Originally Posted by electronistul21 View Post
    Thank You my friend,
    I have the C:\DT2000Data folder.
    Do I need to be connected to a car for the program to run or not?
    Best Regards
  5. #19
    Nov 2012
    You don't need the car. Just the interface conected, and the program wil run.
  6. The Following User Says Thank You to dorofteius For This Useful Post:
  7. #20
    speedy100's Avatar
    Athens
    Quote Originally Posted by dorofteius View Post
    Thanks,
    The program runs, I select a car model and then nothing shows at the scan screen. Please see picture in my post above.
    Best Regards
  8. #21
    Nov 2012
    greece
    hi speedy
    solved the problem??
  9. The Following User Says Thank You to jokas For This Useful Post:
    speedy100 (2nd August, 2015)
  10. #22
    Nov 2012
    electronistul21 is right. You have to copy the database folder that is provided with the software after installing.
    The install does not have any car in database. You have to manualy copy afterwards.
  11. The Following User Says Thank You to dorofteius For This Useful Post:
  12. #23
    speedy100's Avatar
    Athens
    No I have not... it seems like my data base is empty...
  13. #24
    speedy100's Avatar
    Athens
    Is there any link I can download a full database that will work with version 2.9.0.4 please?
    Thank You all for Your time!
  14. #25
    speedy100's Avatar
    Athens
    I have done that to C:\ but no luck...
  15. #26
    use internet explorer8
  16. The Following User Says Thank You to ammarben For This Useful Post:
    speedy100 (4th August, 2015)
  17. #27
    speedy100's Avatar
    Athens
    Quote Originally Posted by ammarben View Post
    I am using I.E 8
    I do not know what else to do...
    Best Regards
  18. #28
    i have hade troubles like you to get ddt2000 work in win7 ultimate 32bits
    than i change to win7 GT pro and it work well
  19. The Following User Says Thank You to ammarben For This Useful Post:
  20. #29
    speedy100's Avatar
    Athens
    I am using windows XP. I had an older version running OK in the past on this same laptop before. But never got this version running all the way to the component selection scan screen.
    I am thinking that it could be the complete installation package that is not good and maybe I should download a different one and try again.
    Any idea about a good working copy with complete data base?
    Best Regards
  21. #30
    i think so
