speedy100 (6th September, 2015)
Why you don't use an old version of ddt2000 like 2.0 or 2.3 ?
I'm using DDT2000 light.Easy and stable.Tryed to connect on banch to ems3132 and sirius32n with vag k+can commander, but with unluck.
Softer working normally like using KKL, but without comunication between vag k+can and ecu.
I think need special addon.
ALBERTO_ (29th September, 2017)
Some instructions for installation that I found on the hard disk.
5n4k3 (9th December, 2017), age9000 (1st November, 2017), Col19 (16th October, 2019), dupisa (19th September, 2017), issaqigu (30th June, 2018), joe06 (29th March, 2017), KWP2000 (26th November, 2017), nedved59 (12th May, 2016), olo_3 (13th November, 2018), rabihfiras (19th June, 2019), romucifer (11th January, 2017), sarigol45 (30th December, 2018), sasa5 (25th June, 2018), Shokunin (8th July, 2017), speedy100 (16th January, 2017), Stelaras (20th April, 2017)
Hi you have a parse error , please post a print-screen of the first page when open ddt2000.
If not use older version .
could some kind person direct me to where i can purchase ddt2000 please.
if you want the software ddt2000 ,it is here in digital-kaos
and also the interface schematic or use vag kkl
I think that here is a mistake.
what can cable will work with ddt2000?
A topic that interests me
hi ammarben.
i cannot find it on this site,can u provide exact location please.............thanx.
for cars on K-Line KKL cable
for cars on Can-Bus Derelek cable ( if somone do know other option please share it )
Well since i never got it working i am back with the starting screen and a Parse error... but i believe it is because of non connection with the "News server"...
== XML-ParseError-SystemError_-2146697211 ==
i have tried to insert a screen capture here but strange... it does not allow me to!!!
B.R.
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
Hi Mates
I m using now windows 7 64, after installation I get error : xmlNews.parseError: cant find ,
all folders are empty, I cant choose any ecu in menu
antivirus is turned off, xml3 downloaded, other database tryed, still same problem
older version of ddt no problem, but I want to use english version
any idea ?
Hola, gracias por los archivos de descarga.
Una consulta, este software se puede usar con el ELM327??
saludos Y gracias
