COBRA1423 IMAGE VER:00.5 IS RELEASED NEW NEW NEW!!!!!
Results 1 to 15 of 29
    Mar 2011
    Default COBRA1423 IMAGE VER:00.5 IS RELEASED NEW NEW NEW!!!!!
    HI EVERYONE OK NEW IMAGE V.005 IS OUT REMEMBER AND READ THE GUIDE SO HERE WE GO ITS IN THE DOWNLOADS AREA ENJOY
    COBRA1423 IMAGE DOWNLOAD HERE--------> ................................................
    ps. I have tried it on sim2.0.1 BUT NOT sim2.10 please let me know if it installs ok.
    Last edited by digicon; 20th March, 2015 at 12:56 PM. Reason: Rules No Links to Other forums
  2. The Following 3 Users Say Thank You to cobra1423 For This Useful Post:
    andiewill (25th March, 2015), DDjnr (21st May, 2016), skingdeven (31st March, 2016)
  3. #2
    Jan 2013
    it works!!but takes lots of time booting when we restart the enigma!!!
    Mar 2011
    Quote Originally Posted by miau18 View Post
    Hi it's set to check the epg that's why it takes a bit longer you can switch it off by going into crossepg configure settinngs and select force epg reload on boot and set it to no. That will make it boot faster hope that helps you out.
    Cheers cobra1423
  5. The Following User Says Thank You to cobra1423 For This Useful Post:
    miau18 (22nd March, 2015)
  6. #4
    Jan 2013
    hi cobra its possible to get zap mode in black screen?when change channel it keeps picture in last channel?thanks
    May 2008
    Mate I flashed my dreambox with it but I had to flssh it back as it wouldent boot and kept loading the bootloader then stop then flash again
    My box always was a lazy starter
    Ive got another dreambox 800 with a ferrari sim is it just a matter of taken the sim card out and changing it and then flash it again
    I think my board is on its way out
    Thanks in advance daniel
  8. #6
    Mar 2011
    Quote Originally Posted by dannyboy View Post
    hi it's for sim2.0.1 &2.10 yes you can change your sim
    Cobra1423
  9. #7
    May 2008
    Is it simple to do and does it usualy take ages for the image to boot up ? Cheers daniel
  10. #8
    Feb 2012
    where can i find the image? thanks
  11. #9
    Mar 2011
    [QUOTE=MW35;2500036]where can i find the image? thanks[
    COBRA1423 IMAGE DOWNLOAD HERE------> http://1drv.ms/1vtnxus
    Last edited by cobra1423; 30th March, 2015 at 02:54 PM. Reason: No Links to other forums
  12. #10
    digicon's Avatar
    The Image can be Downloaded from here:
    https://onedrive.live.com/?cid=48e1ab905262688d&id=48E1AB905262688D%21109
    Please do not post links to other forums with a similar content, it takes a minute or two to actually upload to a file sharing site that everyone can use
    Thank you
  13. The Following User Says Thank You to digicon For This Useful Post:
    ozzy30 (26th December, 2015)
  14. #11
    Nov 2012
    Default Hi all
    I can not get this image to install.
    I'm using sim 2.0.1 and tried to install via browser
    I have the correct bootloader
    It just hangs with the earth picture and flashing red light on dreambox.
    Waited about 20 mins and still the same
    If i try version 00.4b it works perfect.
    Am i missing something or any tips to try, Is it worth trying usb install
  15. #12
    Aug 2008
    Wild Mild West
    Quote Originally Posted by tidsfm View Post
    Yep i would try the usb install, it works good for me.......
    ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
  16. #13
    Feb 2012
    Not working here either just hangs on the Earth screen
  17. #14
    Jan 2012
    Not working here either, stuck on the earth too - flicking red light, tried flashing twice through the web page. Can telnet onto the box as root and top shows nothing doing.
    /var/log message appears to ok for a while and then loops with this every few minutes:
    Jan 1 00:37:06 dm800 user.info kernel: [ 1926.137000] bcmfb: enable manual blit
    Jan 1 00:37:06 dm800 user.warn kernel: [ 1926.410000] alps_bsbe2 is in normal mode now
    Jan 1 00:37:06 dm800 user.warn kernel: [ 1926.436000] alps_bsbe2 is in powersave mode now
    Jan 1 00:37:06 dm800 user.warn kernel: [ 1926.454000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jan 1 00:37:06 dm800 user.warn kernel: [ 1926.454000] set current avs auto aspect to 16:9
    Jan 1 00:37:06 dm800 user.warn kernel: [ 1926.454000] disable wss on display 0
    Jan 1 00:37:06 dm800 user.warn kernel: [ 1926.455000] disable wss on display 1
    Jan 1 00:37:06 dm800 user.warn kernel: [ 1926.455000] set sb to 3(1)
    Jan 1 00:37:07 dm800 user.warn kernel: [ 1927.424000] 4905 ms: 100
    Jan 1 00:37:07 dm800 user.warn kernel: [ 1927.442000] 18 ms: 1
    Jan 1 00:37:07 dm800 user.warn kernel: [ 1927.510000] 68 ms: 6
    Jan 1 00:37:07 dm800 user.warn kernel: [ 1927.556000] 45 ms: 20
    Jan 1 00:37:07 dm800 user.warn kernel: [ 1927.880000] 324 ms: 30
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.225000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.226000] set current avs auto aspect to 16:9
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.226000] disable wss on display 0
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.226000] disable wss on display 1
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.226000] set sb to 3(1)
    Jan 1 00:37:08 dm800 user.info kernel: [ 1928.389000] bcmfb: disable manual blit
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.590000] VIDEO0: set blank to 0
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.628000] sync is off so we enable it
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.628000] playback!
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.628000] total video delay: 0 (0 ms)
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.638000] VIDEO0: start decode
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.649000] flush video decoder
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.855000] VIDEO0: first pts 0x0
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.909000] VIDEO0: set blank to 0
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.910000] VIDEO0: stop decode
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.911000] VIDEO0: set blank to 0
    Jan 1 00:37:08 dm800 user.warn kernel: [ 1928.912000] no decoder left in sync handling so disable xpt_sync
    Jan 1 00:37:11 dm800 user.err kernel: [ 1931.487000] bcm_accel: invalid opcode! 00000080
  18. #15
    Jan 2012
    Installed 00.4a from the same download location and no issues installing that - tried googling the invalid opcode error, but there isn't much on it - possibly driver related? Let me know if you need more info, had this DM800 clone for a few years now and its the first image I've not been able to get to work so must be something quite specific.
    I've not tried messing with the SIM package yet - is there any point in doing so? I messed it up once and had to use a patched version of DreamUp to get back into it IIRC.
