Page 1 of 22 12345611 ... LastLast
Results 1 to 15 of 317
    Default CGW w204 repair FVDI
    Hello I need help repair eeprom cgw.After recalibrating dash FVDI, have no communication with car, CGW only. Press ste many times not work. Flash and eeprom read fvdi OBD.
  2. The Following User Says Thank You to grzanek85 For This Useful Post:
    br.balazs (28th September, 2016)
  3. #2
    Nov 2013
    UK
    Remove battery and reconnect.
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
    Lithuania
    Sent dumps from CGW, eprom and flash, I will see what happen
    Quote Originally Posted by grzanek85 View Post
    seems that you are on the bad side mate:
    Mercedes Benz w204 2008, which does not change the mileage and does not read EZS at all. After few tries did change the mileage and blocked EZS but lost communication via obd2 and damaged ZGW. Damages on W204 - needed to Reprogram ZGW of with SCN coding at authorized BENZ dealer. over cost 800 usd
    br.
    Lithuania
    CGW repair cost 50 eur ....
    cgw dump in first post
  9. The Following User Says Thank You to sepistar For This Useful Post:
    artkiani (20th May, 2019)
  10. #8
    Lithuania
    "About Mileage Correction Function: Don't use FVDI to change mileage for BENZ W212!
    FVDI can't do it, it will reprogram the CGW ( ZGW ) unit automatically, then damage your car.
    Don't use FVDI to change mileage for BENZ Sprinter 906! it possible damge your car dashboard."
    I can say:
    W212 CGW can be repaired without problem, and W906 dash shows"------" can be repaired: make sych with CGW ( EIS ) and km comes back without problem! If have new km in EIS it's will be new km in dash, you no need reprogram dash manually!!!
    PS beter use Abritus instructions and you will not have any problems!
  11. The Following User Says Thank You to Min2xx For This Useful Post:
    car_soft_gorj (5th April, 2017)
  12. #9
    Lithuania
    Your dump repaired, pass PM:
  13. The Following User Says Thank You to Min2xx For This Useful Post:
    ibratex (19th October, 2016)
  14. #10
    hass42's Avatar
    Aug 2012
    USA
    Can I have pass please?
    I have same problem, Really need it. FVDI is a mistake to use.
  15. #11
    ttzag's Avatar
    digital-kaos
    Can you repair this dump for me please ?
    No communication with car after recalibrate odo.
    W204 CGW
    THANX IN ADVANCED
    Actions speak louder than words
  16. The Following 2 Users Say Thank You to ttzag For This Useful Post:
    br.balazs (28th September, 2016), capi (1st April, 2021)
  17. #12
    Lithuania
    Quote Originally Posted by ttzag View Post
    W204 CGW
    THANX IN ADVANCED
    Hi, eprom repaired, write eprom with FVDI and start the car
  18. The Following 6 Users Say Thank You to Min2xx For This Useful Post:
    artkiani (28th January, 2017), br.balazs (28th September, 2016), hass42 (28th September, 2015), megabase (27th October, 2016), ttzag (28th September, 2015), vreditel (26th January, 2017)
  19. #13
    hass42's Avatar
    Aug 2012
    USA
    Can you fix a W164 gateway file I have? If I post?
    Hass42
  20. #14
    Lithuania
    Post dump and details
  21. The Following User Says Thank You to Min2xx For This Useful Post:
    sergo (5th July, 2018)
  22. #15
    hass42's Avatar
    Aug 2012
    USA
    Ok, this would be great if you can, Thanks again
    Its a 2006 ML350
    see which of these files will be best for you.
    Thanks again
