Results 1 to 9 of 9
    ubistvo's Avatar
    SERBIA Krusevac
    Default SOLVED HELP Hyndai I30 2007
    Hello friends i need help for this car
    It came to me and have a problem with start the car each 2-3 time he start
    After i read with diagnostic (no errors) he want to start no more
    and the immo lamp no more light
    I've tried everything but no lucky
    I try to code new key but no lucky every time it say not valid pin
    If some one can help me here is data of car
    Hyndai I30 2007 1.6 CDTI
    VIN: KMHDC51TP8U010259
    I try pin code 405552
    241901
    But not valid
    Here also i read and ECU
    BOSCH 0 281 013 402
    eeprom 95320
    So if someone can make a immo off or read the pin
    This is customer car so i need your help so much
    THANK YOU
    ""Just press THANKS when you think it is useful""
    ubistvo's Avatar
    SERBIA Krusevac
    I need help
    Hello is it have anyone who can help me
    ubistvo's Avatar
    SERBIA Krusevac
    Anyone help me
    PLEASE
    Szczecin;Poland
    Pin code 241901 from this dump.
    No army may enter that land
    That is protected by polish hand
    Unless you are 40 to 1
    Your force will soon be undone
    ubistvo's Avatar
    SERBIA Krusevac
    Aha
    Ok
    But i allready try this pin and SBB say "NOT VALID PIN"
    Problem in SBB its no have I30 i try with diferent type of Hyndai
    Szczecin;Poland
    Try this file and report results.
    ubistvo's Avatar
    SERBIA Krusevac
    bugajewski_pl thanks but i allready solve the problem
    I solve this problem thank to my friend and forum member aslamaslam
    Thank you all who help me
    PROBLEM SOLVED
  8. The Following User Says Thank You to ubistvo For This Useful Post:
    OFFIMO (9th April, 2015)
    autochei's Avatar
    Mar 2013
    romania
    how did u solve?
  10. #9
    ubistvo's Avatar
    SERBIA Krusevac
    Quote Originally Posted by autochei View Post
    how did u solve?
    I do immo off
