not yet, we all waiting for three years
Is there someone known with algo in the eep,
I know it Will synch with nec and old milleage wil be back.
Could someone show me How to Calc milleage in the eep.
Want to do Some Testing.
There is one solution but VW Service is involved...
Solution is for JC dashes before 2015...
To make the programming possible you must change the dash to VDO with same reference number and SW lower than 4269 so you can reprogram it after by OBD2...
After what?
After you take the car to official dealer for dashboard adaptation...
Live by the rules and die by the rules...
Thank before you die...
honingkoning (14th July, 2017)
i have the Vw Golf 7 with VDO cluster and day of manufactured 06.11.2014 and item part number 5G1920732.If i put a VDO cluster with day of manufactured 22.10.2013 and item's part number 5G1920742 it will fit to my car or not? Because at 22.10.2013 cluster it is possible i think the mileage correction.Look at the photos below.
I have done this with a 2015 SEAT Alhambra, Fitted an Older Cluster pre 2014 Coded Immo with ODIS and corrected Mileage with AVDI. Must have Official ODIS with GEKO Access to do this.
it is possible i have done it several times
Can you also replace a vdo instead if a JC ?
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
clearly (25th November, 2017)
The vw golf v5 mk7 2012~ until now.can not be done or is there already a tool for this?.
I have several cars to do cosmetic surgery to look younger the car mercosur.
I would like to know if it is already possible without killing the car?
I put ADVI and it is not possible.
digimaster 3 original obd unknown version.
there are already people in spain who is able to change the kilometers in golf VII does anyone know the tool and is able to do it?
