Results 1 to 11 of 11
    BrunoPT's Avatar
    Oct 2011
    PT
    Default Renault Megane III 1.5 DCI SID307 - DPF
    I need to dpf off on this file.
    Anyone have a work solution for this ecu?
    Renault Megane III 1.5 DCI 110hp
    Year 2013
    ECU : Siemens Sid 307
    Thank you
    Above sea-level
    which tool did you use to read this ecu?
    BrunoPT's Avatar
    Oct 2011
    PT
    Quote Originally Posted by budG60 View Post
    read ecu with x17 tool
    kinketotua's Avatar
    Apr 2016
    Europe
    here
    correct checksum and disconect diferencial sensor presure and exaust temperature sensors
    --> Megane3_sid7dpf.rar
    BrunoPT's Avatar
    Oct 2011
    PT
    Quote Originally Posted by kinketotua View Post
    here
    Thank you.
    this topic is solved, sorry
    Feb 2016
    here
    Please give me a pass
    May 2017
    please the password?
    BrunoPT's Avatar
    Oct 2011
    PT
    put here your files
    EUROPE
    Can somebody remove dpf from this file ecu is sid307 megane 1.5 dci
    eprst's Avatar
    Jul 2011
    Russia
    Hello. Can somebody remove dpf from this file ecu is sid307 Scenic 1.5 dci
    THANKS + REP if I help you
    Jul 2018
    Ukraine
    Year 2013
    HW: 1908R
    SW: 3571R
    VIN nr.:
    SW ver.:
    Spare:
    Engine:
    HW Ver.:
    SW upg.: 3788R
    Installation:
    Thank you
