Page 7 of 21 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 309
  1. #91
    prusony's Avatar
    Belarus
    Quote Originally Posted by yellowstilo View Post
    Thank you, i see you made some more changes to the original schematic diagram - two zener diodes added ( which voltage? ) , a 12v power supply to the relays instead of 5v (so other relays required) and a 4148 diode left out after the voltage regulator - is there a special reason for those changes ?
    thanks again for your great help !
    oops ... I accidentally uploaded yourself version, sorry. Relay coil 12B, and two car sappressor 27 Volt.
    Left diode - reverse polarity protection...
    Non ut edam vivo, sed ut vivam edo.
  2. The Following User Says Thank You to prusony For This Useful Post:
    yellowstilo (21st June, 2015)
  3. #92
    yellowstilo's Avatar
    Quote Originally Posted by prusony View Post
    thank you but i still wonder why you changed the power supply to the relays to 12v instead of 5v and left out the diode after the 5v voltage regulator - your new schematic diagram does no longer match the pcb and component layout although the new setup will probably work ok after some pcb adaptations...
  4. #93
    prusony's Avatar
    Belarus
    It's simple - i have many relay 12V-coil, and have not 5V.
    If relay 12 Volt, diode no needed.
    And finally normal scheme...
  5. The Following 4 Users Say Thank You to prusony For This Useful Post:
    radioman (14th August, 2015), svelent (12th April, 2016), yellowstilo (21st June, 2015), zoro1 (30th March, 2016)
  6. #94
    thank you for your clarification, the last scheme matches the pcb layout again but the other option can be useful for those with a stock of 12v relais (attention to resistance of coil !) and the know-how how to adapt the pcb .....
    Good job !
  7. #95
    Austria
    To add rx,tx from ft need less value... 220ohm for example...
  8. The Following User Says Thank You to oep For This Useful Post:
  9. #96
    paganini's Avatar
    Serbia
    Can somebody help with settings for 16F876? I have TL866 programmer
  10. #97
    Dec 2010
    after virgin/off --> is necessary cut some pin from iaw59f ?
    thanx
  11. #98
    Sarkan's Avatar
    Quote Originally Posted by jordiksvk View Post
    thanx
    No it is not necessary to cut anything.
  12. The Following User Says Thank You to Sarkan For This Useful Post:
    jordiksvk (23rd July, 2015)
  13. #99
    Dec 2010
    i have iaw 5af sw 303
    after decoder - status virgin/off
    but when i plug to car the ecu is coded again,
    how to solve it plz ?
    thanx.
  14. #100
    cubica1's Avatar
    Feb 2012
    Serbia
    thanx.
    that's normally, any virginised device will be automatically coded. You probably need immo off.
    cuby
  15. The Following User Says Thank You to cubica1 For This Useful Post:
  16. #101
    Dec 2010
    and how to do this ?
    i buyed decoder - is possible using decoder? or only way is direct read eep?
    thanx wery much.
  17. #102
    cubica1's Avatar
    Feb 2012
    Serbia
    pictures said more than words
    rgds,
    cuby
  18. The Following User Says Thank You to cubica1 For This Useful Post:
    jordiksvk (27th July, 2015)
  19. #103
    Multipla's Avatar
    Turin,Italia
    Hi friend. The people dont do the pass of rar document but pass of decriptation. Mega have password of is security and is pass of decriptation. Tanks friend give the pass of decript?!
  20. #104
    Dec 2010
    Default Hello pass word pls
    Hello
    please pass
    Can use with Ducati 5am and 59m ?
    Can make it virgin or immo off
    Best REgards
    Quote Originally Posted by Multipla View Post
  21. #105
    Dec 2010
    pass here mean
