Page 8 of 21 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 309
  1. #106
    Jul 2012
    who helps me solve the problem?
    I have built hw 59f decode ..
    chiptuning2 software recognizes hw vetc2rkw ok.
    12v ok but if I press the data do not get reading ECU marelli hw002 !!!
    I checked the PCB and all seems ok, the components are ok 100%
    I wrote a new pic 16f876 with WinPic800 connection using 16f84 to 16f876 via pin
    16f876 pin1,8,20,27,28 to pin PIC16F84 4,5,14,12,13
    write checks ok ok
    Switch confing default file 16f876.hex (hs, 0000h, 1FFFH, boden, WRT, etc ..
    what is the problem? because if I click data does not read ECU 59f?
  2. #107
    Connections are OK?
  3. #108
    Quote Originally Posted by mario38 View Post
    write checks ok ok
    Connections are OK?
  4. #109
    Jul 2012
    Quote Originally Posted by fanos View Post
    Connections are OK?
    you're referring DB9 connection to pin ECU marelli 59f?
    db9; marelli
    1 16
    2 4
    3 17
    4 34 gnd
  5. #110
    araby80's Avatar
    Jun 2013
    INSIDE ECU
    hello
    any body here try to transform iaw59f.m3 hw/303 to iaw5af.p3/hw.303 with iaw decoder?
    because i had transfrom 3 ecus's last week and i descovered that the injection light warning was on ,Check engine light was on too but the RPM and Temperature Gauage are working good!!!! and after i transform i could not able to log in to ecu with any daignostic tool
    another thing when i make immo off for ecu iaw59f.m3/hw.303 and i install it instead iaw5af.p3/hw.303 the RPM and engine Temp. Gauge dose not work but the check engine light and Fuel injection system warning dose not go on .
    finally ...is this any solution for this issue??
    thanks all
  6. #111
    db9; marelli
    1 16
    2 4
    3 17
    4 34 gnd
    This is connections
    connection ECU IAW_MARELLI_59F_FIAT.rar
  7. The Following 2 Users Say Thank You to fanos For This Useful Post:
    badfree (7th May, 2020), houdiag (24th October, 2018)
  8. #112
    hello guys someone could post everything you need to build this tool?
    the link is no longer available
    thank you
  9. #113
    Dufner
    Johnner's Avatar
    Éire
    NO,You've been here 5 years,and still not introduced yourself
    Please do so here : Introduce Yourself
    Thank you...
  10. #114
    sorry I did
  11. #115
    Dufner
    Johnner's Avatar
    Éire
    .......Good stuff !!
  12. The Following 2 Users Say Thank You to Johnner For This Useful Post:
    berard (5th September, 2015), Serg1o (8th September, 2015)
  13. #116
    someone can give the project?
    thank you
  14. #117
    someone has preserved the folder?
    thank you
  15. #118
    Jan 2014
    send me pass please, links are broken
  16. #119
    Hello
    Could someone toss share the entire project, or link
  17. #120
    Jun 2014
    ankara-turkei
    new link without pass,,,please dont forget rep + thanks
    http://www.otocheck.com/DATA/59F_DEC...9F_DECODER.rar
  18. The Following 29 Users Say Thank You to caliskan71 For This Useful Post:
    autocentarvu (12th October, 2015), barsoom (23rd January, 2018), ben1980 (9th September, 2016), berard (11th September, 2015), bmotor60 (10th January, 2016), carmansk (6th October, 2015), credoline (10th March, 2016), d.zio (1st November, 2015), elmaro (27th August, 2017), eric paris (16th May, 2017), Faraday (6th January, 2018), filaalfa28 (17th July, 2017), fuktak (30th January, 2016), haythoumazz (9th February, 2018), jozki (11th September, 2015), kostagrigo (12th October, 2015), mikajna (11th December, 2015), mohamedkey (1st October, 2015), motocarlos (30th September, 2015), Pyromaniak (2nd April, 2018), rico (11th September, 2015), Roturbo (13th September, 2015), ruicosta (10th September, 2015), samyy (18th September, 2015), Serg1o (9th March, 2018), suki1968 (28th April, 2016), svelent (12th April, 2016), vsanyi (5th May, 2018), winaiservice (7th January, 2018)
