Page 10 of 21 FirstFirst ... 5678910111213141520 ... LastLast
Results 136 to 150 of 301
  1. #136
    Quote Originally Posted by yellowstilo View Post
    510 ohm pull-up is the standard value for obd2 k-line devices.
    ok! but for this project 510 ohm could improve?
  2. #137
    yellowstilo's Avatar
    i guess the original layout works for most of us so i would suggest doublechecking your pcb before changing any components - i doubt if changing the 1K resistor will solve your problem but you can always try it....
  3. #138
    Jul 2012
  4. #139
    DK Veteran carmansk's Avatar
    Oct 2010
    World globe
    hi friends
    I have problems with IAW Decoder
    When you program the FT232 BM software detects HW number
    But when we use FT 232 RL and HW = ?????
    Can anyone help?
    Thank you so much in advance!
    my
  5. #140
    prejudice you have the file for the drilling of the PCD?
    Thank you in advance
  6. #141
    I programmed rl working properly
  7. #142
    Quote Originally Posted by mario38 View Post
    yes, that connection is ok....
  8. #143
    hi friends, help reprogram FT232RL 3.3V 5V FTDI USB to TTL Converter Adapter if it is possible do, read eeprom ori ok ,reprog failed
  9. #144
    Quote Originally Posted by berard View Post
    I programmed ftd232rl directly welded on the decoder 59f.
    to reprogram you must first erase the chip, deleted after you install the drivers ftd not those of the decoder 59f and then reprogram
  10. #145
    Quote Originally Posted by crisgsm View Post
    you can take used one but you need original driver for it then you can program wit mprog
    How to clear this FT232RL on this board? the original drivers are the ones of the site of the ftdi?
  11. #146
    hi friend.who have PBC in lay format?
  12. #147
    Oct 2010
    World globe
    mprog drivers for IAW.
    rl232 only for those who have already been programmed for iaw 59
    my
  13. #148
    Also with the new chip does not work! where am I wrong? help
  14. #149
    the project file is not there for the drilling of pcb .. anyone has this file?
  15. #150
    how to program a new chip? unknown Device
