please pass
please pass
read before you ask....it's mentioned several times !
hello ser haw are you
plaize i.need the password
and thanks you
Can you read? Start reading in first post! If you can't find password, then you are not be able build this project!
amper (8th June, 2015)
pass : otocheck
Non ut edam vivo, sed ut vivam edo.
caliskan71 (8th June, 2015)
c'mone you guys, give a man password..
Thanks, Send me pass please
bearheroes (10th June, 2015)
Not just 3 times...3 posts before...not even scroll pages...
Professional BMW immo solutions
Macedonia is one and GREEK!!!
yellowstilo (10th June, 2015)
i just found another error in your schematic diagram - the pin numbers 23 and 24 of PIC 16F876 should be switched , according to the pcb layout pin 24 is the output for relay 1 (+15 switch)
and pin 23 is the output for relay 2 (+30 switch) .
Could you please correct this in your diagram and repost ?
Thanks again for your great help !
prusony (19th June, 2015)
Thank you!
Sorry.
Corrected.
eric paris (5th January, 2018), yellowstilo (19th June, 2015)
Thank you, i see you made some more changes to the original schematic diagram - two zener diodes added ( which voltage? ) , a 12v power supply to the relays instead of 5v (so other relays required) and a 4148 diode left out after the voltage regulator - is there a special reason for those changes ?
thanks again for your great help !
To help develop the project!
