Can anyone generate / compilate the .hex dump for the PIC16F876 to dump for PIC16F876A
Thanks of all!
............................ the problem is solved ..........
Thanks of all!
ecu conection
my doubt that I've found using a tester +12 volts on pin 1 DB9 and DB9 number 2 +12 volt, pin number 3 I did not detect any voltage and pin number 4 DB9 mass gnd .. I wonder is this normal? this link is correct?
you can find that +12 volts on line K?
I think that this can break ECU 59f ..
someone can measure voltage on its DB9?
it seems normal that there are 12 on the line k, because we have a diode and a 1k resistor and then and a 12v weak that only serves to help communication between decoder and 59f. however we expect other opinions of the experts hello
need more one GND on this marked place
speedy100 (30th September, 2015)
that's not the problem .. you can connect the ground to pin 10 or pin 34 ok. but we know that the 4 (+30) pin 17 (+15) = 12volt , pin 16 line k ok no problem to 59f ...
I can not make out the problem !!
the problem came out DB9 is not possible that the pattern includes DB9 pin 1 line k this measure 12volt !!
Ofc kline idles high at +12V, usually pulled up by a 510 resistor to VBatt, in this case they are using 1k.
You should be able to measure the same thing in your car OBD2 port(if it has kline).
Working on something to release next month for free for all dk users :>
12v on K-line is ok like Autodigitec said....
510 ohm pull-up is the standard value for obd2 k-line devices.
