Page 67 of 127 FirstFirst ... 1757626364656667686970717277117 ... LastLast
Results 991 to 1,005 of 1894
  1. #991
    Psa bosch MED17.4/MEV17.4 Can cant read with KESS 5.017 " Error while transferring data in reading" i tested in two cars and the same problem. Citroen C4 5FS Engine. Anybody have the same problems and solve it ?
  2. #992
    heteromies
    Guest
    Quote Originally Posted by michalez View Post
    China Kess version?
  3. #993
    Quote Originally Posted by heteromies View Post
    China Kess version?
    yes it is china kess
  4. #994
    Feb 2013
    UK Bristol
    Hi there.
    I have the same fault "Error while transferring data in reading" but ECU is Bosch ME1.5.5 which is present in Vauxhall(Opel) Corsa C 1.2 16V.
    My kess 5.017 is china but reworked,
    Actually it was just reworked, tested on 2 other ecu and worked ok.
    I try this ecu read via Galetto v54(reworked) and is problem as well.
    So i think is maybe my ecu not readable ....
    At the moment what i read on the internet... My ecu. ME1.5.5 is present in alfa romeo as well. And there no one box can't read this ecu. To the bench as well.. Only option is writing but just overwrite.. With specially trick (pin 10 obd2 connect with Ground or 12v i can't remember now) This is like protection.... Try read more infos in the internet.. Maybe you found something
    Sent from my LG-H990 using Tapatalk
    My post helps you? Please Hit Buttons
  5. #995
    carmageddon's Avatar
    Italy
    fiat-alfa-lancia have bosch m1.5.5 (not readable, only writing)
    http://www.bluestreak.co.uk/img/M1.5.5.%20%20%20WEB.gif
    opel have bosch me1.5.5 (reading and writing by obd without problem...also with kwp2000)
    http://cdn1.bigcommerce.com/server45...00.659.jpg?c=2
    M1.5.5 and ME1.5.5 is not the same ecu
  6. #996
    Oct 2017
    Greece
    Hello people
    I bought recently a KESS V2 5.017 clone
    I try to read the ecu via OBD from a Lancia Y 2002 (IAW 59F). I deal two matters,
    first after the reading it appears a message for check sum error (i read later that needs c++, i install it but i haven't test it yet, to check if the check sum error fixed).
    The second matter is that i read 3 times ecu via obd, each time needs around 35 minutes to complete the procedure and the exported file it was only 256 kb.. What is the necessary avarage time to read a ecu with KESS via OBD. Does it has any setting in order to improve the needed time?
    Thatnks in advance
    Alex
  7. #997
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by alexauto12 View Post
    Hello people
    Thatnks in advance
    Alex
    All ecu have different time of read/write...
    Like edc16c39 read -45min write-2min...
    But for example - me 7.1.1 - read30min write-30min
    Edc16u1 read -10min write-2min
    Merc edc16cp36 - read and write around 2min...
    So time isnt important...
    Files for
    Edc15 are 512kb/1mb
    Edc16 are 1/2mb
    Edc17 2/4mb
    Just check with Winols is it recognized or not...
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
  8. The Following 2 Users Say Thank You to maajkii For This Useful Post:
    alexauto12 (20th November, 2017), Eddie034 (26th November, 2017)
  9. #998
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Hello people
    Thatnks in advance
    Alex
    all that means fiat,it take 30-45 min to read by obd
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  10. The Following User Says Thank You to teamtuner For This Useful Post:
  11. #999
    Oct 2017
    Greece
    Quote Originally Posted by teamtuner View Post
    Quote Originally Posted by maajkii View Post
    Files for
    Edc15 are 512kb/1mb
    Edc16 are 1/2mb
    Edc17 2/4mb
    Thank you mates
    I worried that the my kess had problem.
    One more quetion. my clone has green pcb (not eu version). Is ir worthly to reworked it, due to many components are defferent in comparison with the original? Except components replace do i need to reprogramming the npx processor? (note that i will not change version, my kess has allready 5.017).
    Thank in advanced
  12. #1000
    Oct 2015
    what do you guys think about this kess 5.017 with reset button ? is it worth about 200$ with taxes and shipment ? 5.017.JPG
  13. #1001
    bursuc's Avatar
    Oct 2011
    inside MCU
    Quote Originally Posted by mircea13 View Post
    I would put a bit more and get a proper.eu.clone...
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  14. #1002
    Oct 2015
    does anyone have this kind of 5.017 ? i know is a clone , and a clone is a clone but i want to know if it can be reowrked and if the token button works .
  15. #1003
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    5.017 no need reset button...is unlimited tokens
    outside forum:
  16. The Following User Says Thank You to teamtuner For This Useful Post:
    maajkii (21st November, 2017)
  17. #1004
    Oct 2015
    so it means that this china s..it isn't a 5.017 ? seen on many places advertised as a 5.017 ? wtf ?
  18. #1005
    DK Veteran mariazo84's Avatar
    5017 no token and good internet conection
