TheDevil667 (10th January, 2018)
never seen too!
Pluto all right your ktag with frames !!!!!!!!!!!
hi,
someone used the kess V2 for EDC17CP14 in boot mode?
Hi mbtun, do have some manufacture p/n for the spare parts please? Thanks in advance.
re, Andi
I have fg too which is quite good but ktag is better... did have an issue the other week with a edc17c46 that ktag kept reading badly and so throw its dummy out the Pham but fg did it then used ktag to write it as was changing the software version which fg wouldn't do but ktag does..
Sent from my iPad using Tapatalk Pro
On this new LED BDM frame (pluto2013 has buy), what keeps the probe pens in the frame holes to be pressed on the target board, when i see from picture that diameter of probe pens is less smaller then hole in frame ?
The probe pens are free in the hole for putting them in wanted position but how they make a pressure on target board point ?
Thank you
Hello everyone
I have a kess v2 v 4.036, right now I have the problem of the tokens I have reached the maximum and the machine does not let me upload files.
K10033818 C7514
These are the data of my machine, in the cd that came with the machine comes a file to reset tokens but it does not work. Can you pass a solution to this problem in this version?
hi everybody,
this is my kess V2 i received clone EU FW5.017 with ksuite 2.23
I begin to rework just in soldering the holes , i don' t test it again.
Somebody had tested to extract firmware on the sd card to change the sd card with a better quality (sandisk or transcend for exemple?)
I tried to read the sd card but windows wants to formate the card , the format isn't fat or ntfs is it spécial format?
thanks for you help
photo of my kess.
Hi need sd card tf to kess 4.036
Please
Wysłane z iPhone za pomocą Tapatalk
