Kess V2 Harware Rework - FREE SOLUTION! - Page 74
Page 74 of 127 FirstFirst ... 2464697071727374757677787984124 ... LastLast
Results 1,096 to 1,110 of 1894
  1. #1096
    Myjector's Avatar
    Dec 2017
    Yes i know, i put the led's on my self, can you check it my question before?
  2. #1097
    Dec 2017
    france
    Quote Originally Posted by Myjector View Post
    yes this evening if i have the time, because today job
  3. #1098
    Myjector's Avatar
    Dec 2017
    Ok here also thx in advance
  4. #1099
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Did you check polarity on those 3 led , ar they corect wired, try to resolder mosfet on your pcb , look at all components to be soldered ok , look at diode to be in right pozition, look at your pcb 12 V connector, do you have 12 V on your pcb??
    Trimis de pe al meu SM-G930F folosind Tapatalk
  5. #1100
    Myjector's Avatar
    Dec 2017
    Yes i put the leds in the good direction, i put them on today. All of the components are really good soldered (check it with microscope) and i get power to the mosfet. Yes i have power on my pcb
    I think the problem is that i have no ecu connected the Kess switch the mosfet and give power to wiring i think, bingbang63 will try this evening without ecu also to verify
  6. #1101
    DR Race's Avatar
    Dec 2017
    Dracula's country
    You have to Try with conected ecu!
  7. The Following User Says Thank You to DR Race For This Useful Post:
    Myjector (21st February, 2018)
  8. #1102
    Dec 2017
    france
    hi, i tryed this evening , i haven't power on the red and black wires.
    You are right the voltage is on when ecu is connected and ecu reading.
    could you give me position to solder the led polarity is on the pcb, i know?
  9. The Following User Says Thank You to bigbang63 For This Useful Post:
    Myjector (22nd February, 2018)
  10. #1103
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by bigbang63 View Post
    You can test with your powersuply with low voltage and you will se +/- ok led on +/- not ok led not on / or with your multimeter you can test it as a diode and you will see polarity !!
  11. The Following User Says Thank You to DR Race For This Useful Post:
    bigbang63 (21st February, 2018)
  12. #1104
    Dec 2017
    france
    thank you
    for the polarity all right ! what kind of LED voltage do you use Myjector ?
  13. #1105
    Myjector's Avatar
    Dec 2017
    Hi i use 3v led's and works fine
    And the polarity is marked on the pcb
  14. The Following User Says Thank You to Myjector For This Useful Post:
    bigbang63 (22nd February, 2018)
  15. #1106
    Does anybody have firmware for 4.036 kess i have some from other forum but it does not put crp3 on processor and red light does not coming on when powered. Also if someone have matching kess folder and sd card data for it would be gr8.
    Regards Artur
  16. #1107
    Dec 2017
    france
    sorry i have just KESS V5.017 with ksuite 2.23.
  17. #1108
    will do i think do it have token limit on it and do you have solution to reset tokens ??
  18. #1109
    Myjector's Avatar
    Dec 2017
    Here is an picture of my clone Kess.
    I dont understand why you all solder the holes, i pin them out and they give thru on the other side, sow no real function
  19. #1110
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    I dont understand why you all solder the holes, in pin them out and they give thru on the other side, sow no real function
    great quality ...
    DSG TUNING
    File Service
