Page 79 of 127 FirstFirst ... 2969747576777879808182838489 ... LastLast
Results 1,171 to 1,185 of 1894
  1. #1171
    Myjector's Avatar
    Dec 2017
    Hi Yes it works thru OBD read and write (EU Clone from CN )
  2. The Following User Says Thank You to Myjector For This Useful Post:
    ankjay (9th April, 2018)
  3. #1172
    Newbie matose's Avatar
    Nov 2017
    Bucharest
    Where can i buy original SD cards for Kess 5.017 Red China and KTag 7.020 Red China?
  4. #1173
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Hy , has somebody tested kess 5.017 purple pcb on Peugeot RCZ 1.6 THP 155 hp med 17.4 truh OBD, in my k suite protocole is open and when I click on this car pop up warning , after programming I should turn off all power consumer (clima, radio , el Windows) in order to avoid car going in eco mode, I never made Peugeot cars , any of them , if someone has worked with kess on this ecu truh OBD please post one answer, any answer will be appreciated
  5. #1174
    DR Race's Avatar
    Dec 2017
    Dracula's country
  6. #1175
    Jan 2016
    Jumping Around the globe
    I have a china Ktag that i am trying to make it work...if anyone have solution or can help plz pm me
  7. #1176
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by Locker View Post
    What don't work ?
    Trimis de pe al meu SM-G930F folosind Tapatalk
  8. #1177
    Member rh03's Avatar
    Jul 2017
    France
    [QUOTE = Locker; 3263946] J'ai une Ktag en Chine que j'essaie de faire fonctionner ... si quelqu'un a une solution ou peut aider plz pm moi [/ QUOTE]
    Do you want rework your ktag or you have problem with it ?
  9. #1178
    Jan 2016
    I had a ktag that i bought from china couple years back and never used it
    Last week i had an msv70 swap to do so i decided to try to use the ktag, it worked for reading one ecu so i thought it was good for the job
    the second day i came back to the shop to do the swap, but ktag stopped working, it is giving me the following error:
    k-tag communication errorlease check power connections- 0x100B
    Note that the pc i use is connected to the internet...i donno if this is what caused the problem
    My ktag is old...i donno from how many years i have bought it. I want to know if i am better try to fix it or buy a new one (china or eu clone)
  10. #1179
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    open ksuite...press info button and post all info about firmware version,client code...etc
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  11. #1180
    DR Race's Avatar
    Dec 2017
    Dracula's country
  12. #1181
    Old news, problem solved, thanks to teamtuner!
    Lähetetty minun SM-A520F laitteesta Tapatalkilla
  13. #1182
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by juse View Post
    How did you solve it ?
  14. #1183
    Quote Originally Posted by DR Race View Post
    Got the sw and tool running, there is some holiday in black sea again.
  15. #1184
    Anyone got this http://www.eobdtool.co.uk/wholesale/...u-version.html ? I got one and have problems with reading EDC17C46. Ive tried it with p199 and it reads 10% and then read error. Used some old ktag from a friend and success full reads with it using the same wiring.
  16. #1185
    Quote Originally Posted by ptikkala View Post
    Wise men say that its not as stable as older models
