Page 85 of 127 FirstFirst ... 3575808182838485868788899095 ... LastLast
Results 1,261 to 1,275 of 1894
  1. #1261
    Jun 2018
    Yes I bought Chinese clone that's why I asked for number of parts so I can rework it
  2. #1262
    Dec 2016
    Nathan3001, really?
    Search in the thread mate.
    Everything that you need is here bud. ;-)
  3. #1263
    Jun 2018
    hi bud yea i see info at the start page. but its only giving items needed not the numbers for each chip unless i just cant see it ?
  4. #1264
    Jul 2018
    Is it more worth to buy a china clone and rework it or to buy a EU purple pcb?
  5. #1265
    Jul 2018
    This is how my Kess V2 looks.
    Is it good quality?
    What needs to be changed?
    Thanks.
  6. #1266
    DR Race's Avatar
    Dec 2017
    Dracula's country
    This is what you need to replace, this is how it look a good rework for clone tool,replace all components with good quality one , oscillator murata 8mhz ,replace all capacitor with good quality, kemeth, Panasonic etc. Replace all transistor with original infineon or STI. Replace all 27E diodes, take a look at sd card pins if good sholdered ,and most important, use appropriate software for your hardware, new releas 2.47 is only stupid marketing from.china sellers, 5.017 work ok with 2.22 and 2.23. !
    If I helped you please thenks ,and rep!
    Trimis de pe al meu SM-G960F folosind Tapatalk
  7. The Following 3 Users Say Thank You to DR Race For This Useful Post:
    Gohard20 (20th July, 2018), marcomomma (18th July, 2018), nojmi7 (20th July, 2018)
  8. #1267
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by DR Race View Post
    kess v2 parts with farnell and rs order codes
    Transistors to use :
    5x BCR112 sot23 farnell code: 8737258 must buy 5+
    rscomponents: 287-667 packs of 10
    4x MMUN2113 / PDTA144ET sot23 farnell code: 8736987 must buy 5+
    rscomponents: 690-0133 packs of 25
    3x BC817 sot23 farnell code: 1081223 must buy 5+
    rscomponents: 216-9410 packs of 20
    2x BC807 sot23 farnell code: 1081222 must buy 5+
    rscomponents: 216-9404 packs of 20
    5x NUP2105LT1G / PESD2CAN sot23 farnell code: 1510712 must buy 5+
    rscomponents: 464-255 packs of 20
    Murata filters:
    6x NFE61PT472C1H9L (connect ground for all of them) farnell code: 9528229 must buy 5+
    rs components: 188-8772 pack of 20
    2*1uF - 35V case size C farnell code: 1457460
    2*220uF - 10V case size D farnell code: 1793889
    9*10uF - 16V tantalum case size C farnell code: 1457464
    this are some of component that must replace by reworking kess , replace all component and kess work good
    i dont find anymore complet list for rework if i find rest i will post !
  9. The Following 5 Users Say Thank You to DR Race For This Useful Post:
    djtappage (29th January, 2019), hamedladan (26th August, 2021), jaslen (12th September, 2018), samux (5th August, 2018), zalimhan74 (3rd April, 2024)
  10. #1268
    Jun 2012
    Do you use hot air solder for rework? Or classic solder?
  11. #1269
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by cawadany View Post
    I use induction solder iron, hot air only for removing China components, buy you must take care , not to hot and not to much ,because are many components that you must not remove, you can make this better with aluminum foil, cover with aluminum foil all components and cut off only component to be removed!
  12. The Following User Says Thank You to DR Race For This Useful Post:
    cawadany (31st July, 2018)
  13. #1270
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Sold, no more to give !
  14. #1271
    Feb 2018
    If somebody need a good used kess v2 Euro clone ,with purple pcb please contact me on pm , it is used not new , and it is only 1 , it has no scratch on it ,it looks like new , I send only with DHL insured in Europe, PayPal no problem, tested on many car with success, I dont need anymore, and only stay by me !20180129_173003.jpg20180129_173423.jpg
    I wrote you a pn.
  15. The Following User Says Thank You to akidor For This Useful Post:
    DR Race (6th August, 2018)
  16. #1272
    Mar 2018
    please i need sd card image kess v2 5.017 clone version
    i formated my sd card and had no protocol found error
  17. #1273
    Mar 2018
    Quote Originally Posted by mbtun View Post
    Because some people are making some good money out of it let's make it free for everyone. Photo is of original board so check all others components to be as per this one.
    Thx will be nice.
  18. #1274
    May 2018
    Portugal
    I have a kess v2 green pcb with fw 3.099 and ksuite v2.10 what I can do this to update or reset the tokens?
  19. #1275
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by bolinhos33 View Post
    Trow in Trash can and buy a new one ,update Coast to much!
  20. The Following User Says Thank You to DR Race For This Useful Post:
    juse (11th August, 2018)
