Thank's, really usefull !!
Can someone help on kess rework about speaker soldering, wich hole is + (positive): 1 or 2 ?
Someone knows the reason
And what fixes I can do depends on hardware or firmware thanks
Regarding the Speaker it doesn't matter. The tool will give just a "Beep" on some ford's and jaguar's but you also get a message on the screen. So you can add it or not.
All the hw fixes depend on the pcb.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
wokcz (5th June, 2017)
Hi Gent's
Anybody used to repair or rework tricore adapter for Kess V2, mine stopped working at all, I want to rebuild it.
I have Kess v2 with FW 3.099 . I need help which software work with 3.099 firmware and need sd card files too.
Someone will help with download links ?
3.099 you can use with any Ksuite higher that 2.06.
For the SDcard files you already have them in your toole
I recently bought a Kess SW: v2.32 / FW: v4.036 + KTag SW: v2.13 / FW: v6.070 (shipment hasn't arrived yet). A few days after I placed the order, they started selling Kess SW V2.23: / FW: 5.017 + KTag SW: v2.23 / FW: 7.020.
My question is, if I manage to get the updated fw files, or if the files become available. Will I be able to update with the hardware I bought or will I need to make some physical changes to the pcb?
Hello.
I'm almost sure hardware is same, because some sell NXP including firmware 5.017 and sdcard software.
It's expensive, more than 200?, compare to complete Kess V5.017 + all cables for 290? with DHL.
It's impossible to found firmware only because sellers will lost their business, so only NXP preprogrammed with read security enable.
wokcz (21st June, 2017)
mbtun but I format my sdcard, becouse i had "wake up" error, then I copied to the sd card files for version k-suite 1.89. and run software k-suite 2.32 but when i try to read i have "invalid protocol" error, so i think i need the correct files to sdcard , where
can i find them ?
I am new at this thing and I would like to have a clone KESS. What is the risk of it ? Is it possible that harm ECU with connecting clone KESS via OBD ??
Hello, you can use the clones for ecu's without any ( contenute ) risk, is better you read and write always with same tool, be sure the file you go to write is correct, for some ecu's is better make a full back up with Ktag, and you can be quiet, always thing appaned, you have a full back up.
Professional Tuning Files STAGE 1 / 2 / 3 Cars / Trucks / Agri
Eeuropean fw - sd / Kess Ktag tools
