Hello I have find it on the net, it's very good explained, thanks to their authors:
now I think my red PCB is very very rotten , go work
Could you send photo to see your model RH03 ?
maajkii (13th March, 2018)
mikroel (14th March, 2018)
IMG_20180313_141029 (FILEminimizer).jpgHo un problema con k2 v2 pcb rosso, ho letto iI have a problem with k2 v2 pcb red, I read the file (passat edc16u34 can) .. but at the time of writing the same file read ... it comes out "rsa error" .... the problem is not with file read with fgtech V48.l file (passat edc16u34 può) .. ma al momento di scrivere lo stesso file letto ... esce "rsa error" .... il problema non è con file letto con fgtech V48.
i have a problem with kess v2 5.017 red pcb, i read passat 2.0 tdi edc16u can , but at the time of writing the same file read... it comes oute "error rsa"... the problem is not with file read wiht fgthec v48 .... the problem is file read to kess .... solution?????IMG_20180313_141029 (FILEminimizer).jpgIMG_20180313_141029 (FILEminimizer).jpg
problème only with edc16u vag ? or it is ok with other car/ecu ? I have read somewhere, kess china don't work fine with edc16u vag.
i tested renault megane 1.5 2004 , ecu delphi ... same problem. (galletto r/w ok) kess v2 red pcb no work! i possible file inside sd card???
I have same pcb and mine works good, but like mine, it need rework.
What do You think about this clone? I must do rework? What i need replace or correct?
https://drive.google.com/folderview?...mo2z7UhWkmVXwv
Kayhan 17# (11th April, 2018)
someone has internal file sd card kess v2 red pcb 5.017 ??? and procedure to replace the file on the new sd card. Thank you
