do not play with ktag ...is not a ball...
prejudice I tried your solution with fw fw 4,024 to 4,036 npx not locked after update obtained protocols active bike car dsg
how can I do to have full protocols ?I ask those of you who keep files for sd card for fw 4024 ?
Nxp is not locked crp3 after update from 4.024 to 4.036? If this is true than we already have working solution ...
mexanico1971 (2nd May, 2015)
not yet...
those of you who file sd card for fw 4024 ?
if you have now 4.036...what for you need sdcard for 4.024 ?
4.024 have trucks protocols active ... one of the most important reason I need kess. Otherwise there are very few new cars comparing to the other tools.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
fw 4024 has the right protocols activated for trucks serve this file sd card........the fw exists only missing files sd card if you have a solution
@ 8.23.motor - you updated from 4.024 to 4.036 ... your NXP is locked or not? can you reflash now or not?
npx not communicate more and even link j uart ( tx rx gdn )
hello mate. what cfg did you ussed during update ?
post there the cfg from the pack that is posted. activation of protocols is linked in cfg file or device.fmw
I used the config file posted in the solution betrescudan and fw 4024 skipe :cuozzo80
