Page 89 of 127 FirstFirst ... 3979848586878889909192939499 ... LastLast
Results 1,321 to 1,335 of 1894
  1. #1321
    May 2018
    Quote Originally Posted by Hexer84 View Post
    Hi Guys,
    i read the whole Thread but still have one question.
    The Thread started in 2015 and my kess and ktag arrived yesterday. I am asking myself If the rework posted in 2015 is still the same for my pcb.
    Would you please have a look on it and tell me which parts needs definetly a rework to have a good working kess/ktag?
    I appreciate your Help.
    Nobody?
    Gesendet von meinem SM-G930F mit Tapatalk
  2. #1322
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I try to read-write one edc17c19 with ktag reworked China clone... sometimes work sometimes don't, I am sure is s/w problem... Can
    You suggest any good tested ksuite 2.23 version?
    (I have all ready try the supplier's version and a version from that who rework my ktag... Both not working correctly on that ecu....
    Thank you
  3. #1323
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by Panathaole View Post
    Thank you
    This ecu it should be a problem even for no reworked ktag , this one is tested and work olsow on EDC 17 c59 opel
    https://mega.nz/#F!27AzwaRD!-CTFpcxouxdnflhJSM27-Q
    Trimis de pe al meu SM-G960F folosind Tapatalk
  4. The Following User Says Thank You to DR Race For This Useful Post:
    Panathaole (4th October, 2018)
  5. #1324
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Nobody?
    Yes still the same ,hardware is same as 2015 only newer software ,if you whant stabile tools make rework!
  6. The Following User Says Thank You to DR Race For This Useful Post:
    Hexer84 (4th October, 2018)
  7. #1325
    May 2018
    OK, thank you.
    i have to look where the post is which listed all compnonents that needs to change.
    Do you have a list and a picture, DR Race?
  8. #1326
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by DR Race View Post
    thank you
    2.23v NET SAFE i guess...? right?
  9. #1327
    DR Race's Avatar
    Dec 2017
    Dracula's country
    thank you
    Yes no problem with internet
  10. #1328
    taken from another site:
  11. The Following User Says Thank You to u.s For This Useful Post:
  12. #1329
    May 2018
    Quote Originally Posted by u.s View Post
    Thank you.
    Is this even usable for the red pcb i own?
  13. #1330
    yes it is mate
  14. #1331
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i download and install this version.... same problem.... in beginning can't read, error after a while.... finally i read it but cs error at the end...
    maybe my ktag have hardware problem? (reworked by a very experiment user)
  15. #1332
    DR Race's Avatar
    Dec 2017
    Dracula's country
    I can send you another version, but this one I have send to you is personally tested by me , manny ecu done with no problem I think some components on your ktag not fitted ok or damaged ,I have no idea ,but this ecu it should not be a problem even for China pcb
  16. #1333
    DR Race's Avatar
    Dec 2017
    Dracula's country
    What about your power source, it has enough power, if power source is not ok happen same problem ,try to use one good car battery as power source 80 Amp if it work then your power source is bad
  17. #1334
    May 2018
    Try to Update/Install certain net Framework to fix checksum errors!
  18. #1335
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i have a cheap regulated power adapter 3A.... i think this is not a problem.... i repair dotnet 4.5 (all ready have c++2005 2008 2010 2012)
    in other ksuite i replace dll with other , that i found in forum.... cs seems to be ok but i cant write in ecu.... 100% write and Stuck.....
    all ways have cs error...
