https://mega.co.nz/#fm/UIMFXA7I
this link will not access your account...regards
Can someone check this token rest and tell us if its anygood, I got of a friend
rickymix34 (7th August, 2015), STEEVYAS (28th December, 2015), vari (15th June, 2017)
The file and rar are corrupt. Please try to re upload the proper version
TUNING FILE SERVICE SINCE 2008
GOOD FOR NOTHING....
is not corupted...is virus sallity...pfff
No that.... JUST NOT WORKING!!!
Hey guys,
there are two black wires going to the left on the picture at the top left position (MM1 and RF), whats the purpose of this or should i just fill up the both holes?
also i have a single SMD Resistor on the back of the board with 1000 on it, is that the famous resistor of the clones?
the black wire is grounding against electrostatic discharges. yes fill the holes. use my solution & photo, replace all transistors and remove the resistor on the back.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
Kayhan 17# (17th May, 2015)
mate, what kind of part is the "SP1", i dont have that on my board and there is no parts description =(
photo ... i don't understand
oh sorry =)
the red circle above ESMT Chip
speaker piezzo = PKM17EPP (muRata manufacturer)
Which parts solved the 24V problem?
you tried your tool and is not working on 24V? after you replaced all components as per my photo and not working? I don't think so ...
