Bought this from China advertised as 24v trucks 30 tokens.
Can anyone confirm this PCB is correct before I attached to truck
For trucks the tool is generally good to go BUT it's very good idea to replace the 2 x high voltage suppressors from the china clone.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
Faraday (25th May, 2016)
hi friends i have kess v2 whit SW: v2.15 FW: v4.036 china, i need tuning fiat panda 1.2 whit ecu marelli 9gf , family 479 but it is grey i not can select!!what i can do?possible activate this family?regard alex
Just not to be selfish, you give the photo to change the components. This is a forum and it is right that some things are shared with the entire board. TKS for all.
beongo (19th June, 2016), GianniNOS (17th June, 2016), Kayhan 17# (16th June, 2016), mexanico1971 (26th October, 2016), wen20v (30th January, 2018), xirtam (18th June, 2016)
If any have a protocol 479 or other protocol post here and it explains how to update their tool. It makes no sense to update the kess with other bin file then if there are no new protocols. You can stay even with 3.099 and 2.11 software, important to have protocols. In kess 3.099 have a protocol gray Iaw 9gf in Fiat 500L important that it is enabled.
My 2,06 3.099 fail reading Passat MED17.5 in OBD (by the way original Kess with latest SW/FW fail it too) and fail reading EMS3110 (fluence GT TCE180 engine) both start reading and fail about 70~75%
anyone has experience with this ?
MPPS V13 is safe to writing EM3110 ? I read a lot of then but didn?t try to write
i have just purchased the kess v2.23 with 4.036 fw
i also bought the ktag 2.13 is there any newer sw / fw for either of these devices ?
All kess function by one software but are old firmware and software are 2.08 2.099 firmware is very sodisfacent good firware for kess is 4024 but you have a good pcb of kess. Know you spect to decide what kess you have and what firmware you want. If you want super kess decide 4.036
Kess_4_036.zip
Hello has a problem in downloading the files zip and rar please help
