ankjay (9th April, 2018)
Where can i buy original SD cards for Kess 5.017 Red China and KTag 7.020 Red China?
Hy , has somebody tested kess 5.017 purple pcb on Peugeot RCZ 1.6 THP 155 hp med 17.4 truh OBD, in my k suite protocole is open and when I click on this car pop up warning , after programming I should turn off all power consumer (clima, radio , el Windows) in order to avoid car going in eco mode, I never made Peugeot cars , any of them , if someone has worked with kess on this ecu truh OBD please post one answer, any answer will be appreciated
I have a china Ktag that i am trying to make it work...if anyone have solution or can help plz pm me
[QUOTE = Locker; 3263946] J'ai une Ktag en Chine que j'essaie de faire fonctionner ... si quelqu'un a une solution ou peut aider plz pm moi [/ QUOTE]
Do you want rework your ktag or you have problem with it ?
I had a ktag that i bought from china couple years back and never used it
Last week i had an msv70 swap to do so i decided to try to use the ktag, it worked for reading one ecu so i thought it was good for the job
the second day i came back to the shop to do the swap, but ktag stopped working, it is giving me the following error:
k-tag communication errorlease check power connections- 0x100B
Note that the pc i use is connected to the internet...i donno if this is what caused the problem
My ktag is old...i donno from how many years i have bought it. I want to know if i am better try to fix it or buy a new one (china or eu clone)
Trimis de pe al meu SM-G930F folosind Tapatalk
Old news, problem solved, thanks to teamtuner!
Lähetetty minun SM-A520F laitteesta Tapatalkilla
Anyone got this http://www.eobdtool.co.uk/wholesale/...u-version.html ? I got one and have problems with reading EDC17C46. Ive tried it with p199 and it reads 10% and then read error. Used some old ktag from a friend and success full reads with it using the same wiring.
