Page 70 of 127 FirstFirst ... 2060656667686970717273747580120 ... LastLast
Results 1,036 to 1,050 of 1894
  1. #1036
    Aug 2009
    netherlands
    Quote Originally Posted by TheDevil667 View Post
    No The resistance
    Gesendet von iPhone mit Tapatalk
    Never seen before
  2. The Following User Says Thank You to pluto2013 For This Useful Post:
    TheDevil667 (10th January, 2018)
  3. #1037
    Dec 2017
    france
    never seen too!
    Pluto all right your ktag with frames !!!!!!!!!!!
  4. #1038
    Top Poster TheDevil667's Avatar
    Apr 2017
    Austria
    Quote Originally Posted by bigbang63 View Post
    never seen too!
    He he
    But Is working fine !
    I also wondering what do this resistance ?
    Do Not Forget
    THANKS & REPUTATION !!
    Kind Regards
  5. #1039
    Dec 2017
    france
    hi,
    someone used the kess V2 for EDC17CP14 in boot mode?
  6. #1040
    Jan 2017
    Hi mbtun, do have some manufacture p/n for the spare parts please? Thanks in advance.
    re, Andi
  7. #1041
    Jun 2011
    Northamptonshire, UK
    hi,
    I am pretty sure I have without any probs.. but most times for any boot mode Ecu’s I use ktag..
    Sent from my iPhone using Tapatalk Pro
  8. #1042
    Dec 2017
    france
    Quote Originally Posted by Music73 View Post
    thank you, i have a FGtech V54 too, it's good to do boot mode on edc17 tricore , I never test it .
  9. #1043
    Jun 2011
    I have fg too which is quite good but ktag is better... did have an issue the other week with a edc17c46 that ktag kept reading badly and so throw its dummy out the Pham but fg did it then used ktag to write it as was changing the software version which fg wouldn't do but ktag does..
    Sent from my iPad using Tapatalk Pro
  10. #1044
    credoline's Avatar
    Србија
    On this new LED BDM frame (pluto2013 has buy), what keeps the probe pens in the frame holes to be pressed on the target board, when i see from picture that diameter of probe pens is less smaller then hole in frame ?
    The probe pens are free in the hole for putting them in wanted position but how they make a pressure on target board point ?
    Thank you
  11. #1045
    Jun 2011
    Quote Originally Posted by credoline View Post
    Thank you
    Tbh the holes are a lot bigger than the pins.. bt the pins are quite weighted so they hold there own but they do not push the pogo pins down but is enough to make a connection...
    Sent from my SM-G935F using Tapatalk
  12. #1046
    Nov 2009
    EUROPE
    v54 and v53 is very good on edc17c46
  13. #1047
    Aug 2015
    SPAIN
    Quote Originally Posted by Multipla View Post
    My file is EU try of this. Rework. If you thing is bad kess.
    pass pls friend 4.036 fimw
  14. #1048
    Nov 2016
    Hello everyone
    I have a kess v2 v 4.036, right now I have the problem of the tokens I have reached the maximum and the machine does not let me upload files.
    K10033818 C7514
    These are the data of my machine, in the cd that came with the machine comes a file to reset tokens but it does not work. Can you pass a solution to this problem in this version?
  15. #1049
    Dec 2017
    france
    hi everybody,
    this is my kess V2 i received clone EU FW5.017 with ksuite 2.23
    I begin to rework just in soldering the holes , i don' t test it again.
    Somebody had tested to extract firmware on the sd card to change the sd card with a better quality (sandisk or transcend for exemple?)
    I tried to read the sd card but windows wants to formate the card , the format isn't fat or ntfs is it spécial format?
    thanks for you help
    photo of my kess.
  16. #1050
    Dec 2017
    Hi need sd card tf to kess 4.036
    Please
    Wysłane z iPhone za pomocą Tapatalk
