Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
    electrones's Avatar
    Feb 2012
    Around C.V
    Default Zadi immo box KTM RC8 1190 help please!!!
    Hi friends
    Can someone help me with immo box zadi SML0322
    I need to know how to open this zadi immo box and location eeprom date please!!!
    Thanks in advance
    Press "THANKS" button. just one click, CHEERS
    gepakg's Avatar
    Serbia
    first photo,left up corner make 10 x 10mm will have an 24lc04 in ssop8
    regards Gepa
    Quote Originally Posted by electrones View Post
    Hi friends
    Thanks in advance
  3. The Following 6 Users Say Thank You to gepakg For This Useful Post:
    electrones (8th May, 2015), Hanukkah (9th May, 2015), igorr (7th May, 2015), instakeys (8th February, 2017), PremierD (8th May, 2015), Siham (8th July, 2015)
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by gepakg View Post
    regards Gepa
    I have had some probs to get one adpter for tssop but i have got one from ecuvonix, so i have read the data from 24c04 and i need help to do new transponder for this bike
    I?ll appreciate your help..
    Thanks-cheers
  5. The Following User Says Thank You to electrones For This Useful Post:
    david key works (2nd January, 2020)
  6. #4
    electrones's Avatar
    Feb 2012
    Around C.V
    Someone can help me to add new key for this bike please!!!
    gepakg's Avatar
    Serbia
    what tool & transponder you mean to use to write transponder?
    BTW. Somebody little play with this bike as i see on dump:-)
    regards Gepa
  8. The Following User Says Thank You to gepakg For This Useful Post:
    gwee (12th July, 2015)
  9. #6
    electrones's Avatar
    Feb 2012
    Around C.V
    Thanks friend
    I have Zed Bull & tagkey tool but not support this bike, transponder is 4D60 or tpx2.
    My idea add key on dump.
    Cheers
  10. #7
    leandroks's Avatar
    Brazil
    Sorry m8, as long as i know just tmpro2 can do that.
    But post the transponder logical data and we can try to get u some help
  11. The Following User Says Thank You to leandroks For This Useful Post:
    electrones (13th July, 2015)
  12. #8
    gepakg's Avatar
    Serbia
    as i said in previous post somebody play with this bike and i see it in dump,on address h70-h80 miss something:-) also that thing missing on h140-h150
    also missing something to complete an tpx2 to be working
    this bike is equipped with keihin ecu with 93c56 inside and have sync with immo,when that this two thing will be original and paired then he have position to make working key,for now for sure nothing
    BTW.tmpro ktm immo zadi type1 immo is maked with bogi & me,huge testings with it:-) because i said that is dangerous making master key that can do sync / de-sync ecu---immo
    regards Gepa
    Quote Originally Posted by leandroks View Post
  13. The Following 3 Users Say Thank You to gepakg For This Useful Post:
    electrones (13th July, 2015), gwee (12th July, 2015), Siham (12th July, 2015)
  14. #9
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    As I can see Pg4 is missing in this dump.
  15. #10
    gepakg's Avatar
    Serbia
    he is in dump but little flowed from right position as i said because of playing with this bike,few things missing...any bike especially KTM is not toy that old rich kids play with it:-))))
    regards Gepa
    Quote Originally Posted by simaservis1108 View Post
  16. The Following 2 Users Say Thank You to gepakg For This Useful Post:
    electrones (13th July, 2015), simaservis1108 (12th July, 2015)
  17. #11
    Aug 2013
    Serbia,Belgrade
    Could the dump be fixed?
  18. #12
    gepakg's Avatar
    Serbia
    yes,can be but with support of ecu dump and some data from it...i told again,these thing are not toys for rich guys:-)))))
    regards Gepa
  19. The Following 3 Users Say Thank You to gepakg For This Useful Post:
    bearheroes (14th July, 2015), electrones (13th July, 2015), gwee (13th July, 2015)
  20. #13
    electrones's Avatar
    Feb 2012
    Around C.V
    regards Gepa
    Thanks gepakg, simaservis1108
    all friends that helped)
    Thanks m8s for your attention here is picture from ECU, if u can help me with location eeprom in side, i'll appreciate
    Cheers
  21. #14
    Member cemox's Avatar
    Kampala
    Default ktm
    Hello
    your dump is not good you cant start bike with this dump
    dump corrupt after try to coding new key ??
  22. The Following User Says Thank You to cemox For This Useful Post:
    electrones (17th July, 2015)
  23. #15
    Hollywood
    Are you sure some data is missing?
    I think file is OK. I see all important data.
  24. The Following User Says Thank You to Master01 For This Useful Post:
    yuranan (21st March, 2017)
