I tried Temic OLS file for mine but.. seems to be another file cant findcorrect adresses.. hmm
Haha really.. ill try that.. So what you mean is that i open a map in TEMIC OLS and save it as Lo HI? and then do a search again ?
Thank it worked.. Thats Hillarious.. But if ont tune these maps it will be a pressure based tune.. wouldnt that be the wrong wa to do it?
Im looking after if there is a delay time for the Launch control.... LoL im loosing every race due to when i release the brake it take time for the engine to lauch... Very disturbing... OEM launch suck big time..
Heheh oke.. you mean skip the DSG?s launch and do it in the ECU.. :-)
Hi can someone help at the new Golf7 GTI with the DSG.
I have a stage I but it is not enough.
At the Engine ist Stage III (with Downpipe ....... )
I need Stage II or Stage III for the DQ250
The car is 09/2016
GTI 09-2016.rar
if u have one stage III you can post it here. here are many people who want it for free
in the new dsg is nothing other than earlier dsg all the same way. use your brain and you found a solution :-)
and without your tuning file and see no logs from the car trq output nobody can do it correct.
the engine ecu give a trq out and the Dsg use this but the dsg check this and calculate the trq by self .
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
immoneard (28th October, 2022)
How many mAmps did you increased to the max strom kummpungsmoment? How much did you set the pressure on Maximaler Hauptdruck. And about torque limiters? Did you remove it?
Because I have my car with more than 600Nm of torque and clutches are slipping at 12 bars. I think the DSG open voluntary the clutches to reduce the torque.
What do you think?
Thanks.
hi can somebody check this DSG remap in attachment is ORI and REMAP Lauch Control activated and some modification, can somebody do more on this DSG remap in wich stage is remaped this DSG ???
DSG ORI + REMAP.rar
harold1987 (28th June, 2023)
