Hi to all ..it is my first post here ,although i read this forun a lot .
I have almost the same problem with a dq250 tcu file (Exx series ) .I have raised the above maps but the maximum clutch pressure i get is 13.03 bar, i have raised tq limiters,i have make shift time way faster and some other functios but i wan to raise clutch pressure . The car is making near 520-540nm according to vcds ...So any more info about the above maps or if there is anything else i have to do in order to see above 14bar or even better 16bar is kindly welcomed . I attach photos from the maps listed above and how i have scaled them.
I m open to all suggestions
Teoclutchcorrectimage.jpgclutchcorrectimage.jpgclutchcorrectimage.rar
Anyone ? any opinon?
I'm wanting to raise mine what interface and lead do i need
why i can't download ols file?
for all with cmd kess no way to raise clutch pressure
only with byteshooter and sheepshooter it work great :-)
some code must modified
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Hi i can increase clutch pressure on DQ250 up to 16bar.
It's only proper tuning, nothing more.
TUNING FILE SERVICE SINCE 2008
immoneard (28th October, 2022)
than show me your solution i can do it only with implement code
My understanding is that the N215 & N216 clutch valve needs to be modified, but where they are? The main valve map is not enough I think.
Don't forget this map "Daten Moment zu Hauptdruck KL" It converts the torque to pressure, so check "Stuetzstelle Moment zu Hauptdruck KL".
Regards Chris
Apsik (8th January, 2018)
I use X17 magic by OBD, but i never tried with kess. What is the problem in kess? Writing partial?
Do you have a skype?
X17 work also obd yes Write Partial
