kess maybe only old dq250 read parital obd
direct read file same sgo converted file not parital
Hi, i ve modified clutch pressure to 18 bar for stage 3 hybrid turbo on my mqb.
I need to raise value on « Strom in ma », Stock value is 1750 for 12 bars.
Could you tell me the exact value for 18 bars ?
I've found all maps... but can someone explain what they do ?
- Minimum main pressure when shooting : from 12bar -> to much more... right?
- max current for max clutch torque for k1-k2: from 1400mA -> much more mA till ?
- Target current for main pressure valve: how does it works this map ?
- maximum main pressure: increase over 20bar?
- Factor on main pressure offset from target pressure: how does it works this map?
- Main pressure for insertion: increase pressure bar i can magine
Here other question...for clucth pressure increase... change the trq output in engine ecu ? But which map are you talking about?
In dsg also if you have more then 500nm...better to not increase over...for clutch pressure?
Thanks in advance.
Hi Icezero2010, please can you tell me how to modified with kess and cmd. I need 18.5 bar in my dq 250. Thank you.
