Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 54
  1. #31
    Aug 2015
    what about gear shift time can be change for fast shift change ?? :$
  2. #32
    Aug 2012
    Quote Originally Posted by purepower View Post
    How many mAmps did you increased to the max strom kummpungsmoment? How much did you set the pressure on Maximaler Hauptdruck. And about torque limiters? Did you remove it?
    Because I have my car with more than 600Nm of torque and clutches are slipping at 12 bars. I think the DSG open voluntary the clutches to reduce the torque.
    What do you think?
    Thanks.
    check KzuPHauptMin_ko
    KusIMax_ko[K1]
    KusIMax_ko[K2]
    GsaAdaptEingDurchpHaupt_ko
    HdrPHauptZuI_kf_z
    i think this is enough
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  3. The Following 4 Users Say Thank You to icezero2010 For This Useful Post:
    immoneard (28th October, 2022), liam987 (16th January, 2017), mytunes (19th May, 2017), teobolo (14th January, 2017)
  4. #33
    Feb 2016
    Hi to all ..it is my first post here ,although i read this forun a lot .
    I have almost the same problem with a dq250 tcu file (Exx series ) .I have raised the above maps but the maximum clutch pressure i get is 13.03 bar, i have raised tq limiters,i have make shift time way faster and some other functios but i wan to raise clutch pressure . The car is making near 520-540nm according to vcds ...So any more info about the above maps or if there is anything else i have to do in order to see above 14bar or even better 16bar is kindly welcomed . I attach photos from the maps listed above and how i have scaled them.
    I m open to all suggestions
    Regards
    Teoclutchcorrectimage.jpgclutchcorrectimage.jpgclutchcorrectimage.rar
  5. #34
    Feb 2016
    Anyone ? any opinon?
  6. #35
    Jul 2016
    I'm wanting to raise mine what interface and lead do i need
  7. #36
    Nov 2015
    why i can't download ols file?
  8. #37
    Aug 2012
    for all with cmd kess no way to raise clutch pressure
    only with byteshooter and sheepshooter it work great :-)
    some code must modified
  9. #38
    DK Veteran Overtune's Avatar
    Aug 2009
    Hi i can increase clutch pressure on DQ250 up to 16bar.
    It's only proper tuning, nothing more.
    TUNING FILE SERVICE SINCE 2008
  10. The Following User Says Thank You to Overtune For This Useful Post:
  11. #39
    Aug 2012
    than show me your solution i can do it only with implement code
  12. #40
    Jan 2017
    My understanding is that the N215 & N216 clutch valve needs to be modified, but where they are? The main valve map is not enough I think.
  13. #41
    Dec 2009
    Don't forget this map "Daten Moment zu Hauptdruck KL" It converts the torque to pressure, so check "Stuetzstelle Moment zu Hauptdruck KL".
    Regards Chris
  14. #42
    daynight's Avatar
    Nov 2016
    EU
    Quote Originally Posted by icezero2010 View Post
    What you mean with this?
  15. #43
    Aug 2012
    Quote Originally Posted by daynight View Post
    after some tests i have also a solution for kess and cmd obd write :-)
    up to 18,5 bar
  16. The Following User Says Thank You to icezero2010 For This Useful Post:
    Apsik (8th January, 2018)
  17. #44
    daynight's Avatar
    Nov 2016
    EU
    I use X17 magic by OBD, but i never tried with kess. What is the problem in kess? Writing partial?
    Do you have a skype?
  18. #45
    Aug 2012
    X17 work also obd yes Write Partial
