Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 114
    Default FINAL SOLUTION to IMMO OFF SAGEM - VALEO S2000 PL4FC5 - 3 VERSIONS SERIAL 95160
    HI FRIENDS. I have seen several threads where NOT TO GET A PROPER solution for IMMO OFF IN CENTRALs VALEO OR SAGEM S2000PL4FC5. This is because there are three different types of ecu named s2000pl4fc5 and 3 respective software immobilizers in his serial mems 95160. I have the total solution for this 3 variations.
    If you need to solve your immo off problems in these ECUs, just send here your Original DUMP and i will answer you in few hours with your dump.
    Best Regards Pals
  2. The Following 30 Users Say Thank You to martinbecks For This Useful Post:
    acmotor (1st July, 2015), ALVARES (1st July, 2015), Caarlosalfredo (3rd September, 2021), carlab237 (30th March, 2018), diegoj (21st August, 2020), Ecumotor (11th February, 2020), greg6969 (31st August, 2023), ivanmpenev (18th August, 2018), julo45 (2nd September, 2015), KADE007 (3rd July, 2019), kasim_izmir (18th February, 2021), key4man (1st July, 2015), llaverosv (30th August, 2015), mancinofranco (12th May, 2015), meganegro (17th July, 2020), mohamedkey (2nd July, 2015), Mr Mo (20th February, 2016), Mvt (18th July, 2020), npena (27th September, 2023), OFFIMO (12th May, 2015), oscarcorra (3rd July, 2019), pezao (2nd July, 2015), racingpowerchip (5th February, 2016), sergei5005 (20th February, 2016), Toutancamon (20th July, 2022), vicrom2010 (22nd December, 2015), yoret (28th April, 2021), zziad (15th June, 2015)
  3. #2
    Dec 2013
    95160.rar
    s2000pl4fc5 hello Friend can make out this thank file
  4. The Following User Says Thank You to OFFIMO For This Useful Post:
    br.balazs (23rd June, 2017)
  5. #3
    thanks friend
  6. The Following 2 Users Say Thank You to mancinofranco For This Useful Post:
    ahcen elctro (12th October, 2019), oscarcorra (2nd July, 2019)
  7. #4
    Dec 2014
    You need Dump in ECU or BSI ?
  8. #5
    Jun 2013
    Default s2000 pl4fc5 9659552780
    hi friend can u help me with this file? thanks!!!
    original s2000 9659552780 95160.rar
  9. The Following User Says Thank You to a2000 For This Useful Post:
  10. #6
    Hi acmotor. Ecu Dump.
  11. The Following User Says Thank You to martinbecks For This Useful Post:
  12. #7
    Hi a2000 i will see your dump in a few hours. please be patient. Dont forget put thanks please.
  13. The Following 2 Users Say Thank You to martinbecks For This Useful Post:
    a2000 (15th June, 2015), nasbadboy (19th July, 2020)
  14. #8
    Hi a2000. Here you are your immo off file. Pass in PM. Regards.
    Valeo S2000 Sin Inmo.rar
  15. The Following 8 Users Say Thank You to martinbecks For This Useful Post:
    a2000 (24th June, 2015), nasbadboy (19th July, 2020), npena (27th September, 2023), oscarcorra (3rd July, 2019), rlnservice (1st July, 2015), rodrigobsas (9th December, 2015), scaglione (11th August, 2020), thaeerkh (28th August, 2018)
  16. #9
    Hi OFFIMO, i dont understand if you need my services.
  17. #10
    Nov 2010
    Default Need Help Valeo S2000
    Hi martinbecks
    please need help whit this ECU, Need immo off
    Valeo S2000
    part number 21585427-5 A
    Serial Number 7192 273298
  18. #11
    Dec 2014
    Default Peugeot 206 1.4 Valeo ECU dump
    Hello sir, can you make immo off for this ECU ?
    Thanks in advance
  19. #12
    Apr 2012
    Default Hi Friend
    Please can IMMO OFF S 2000Attachment 320742
    Thanks you
  20. #13
    May 2015
    argentina
    Hello friends
    if you use this file to immo off
    stops working rpm on the dashboard?
  21. #14
    May 2015
    argentina
    hello, I have a problem.
    I do not have the original dum .
    I have some other solution?
  22. #15
    Feb 2016
    hello friend can u help me with this file? Thankssagem2000.95160.ori.rar
  23. The Following 2 Users Say Thank You to racingpowerchip For This Useful Post:
    DAVID8HENRY8 (12th July, 2017), thaeerkh (28th August, 2018)
