Page 13 of 13 FirstFirst ... 38910111213
Results 181 to 192 of 192
Thread: XC MINI CONDOR
  1. #181
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by lush29 View Post
    Hi all. Have an prob. I am trying to decode and cut an spare key for range hu101 key. So i chose hu101 ford and try to devode but snapped 3 probes on me so far. Is any try hu101 happen the same or my machine is problem? Or ford keys are still problem? Thanks
    Complete my fault meant to choose 10 pins not 7. Sorry again.. thx
  2. #182
    melbourne, australia
    Hi guys, I'm having some problems cutting a mercedes a mercedes hu64 with my condor. Its not the mini, but think support would be the same & this thread is more active than the condor support thread.
    Basically the blades I cut wouldnt work & didnt look the same. I tried a few things & couldnt get it to work. I ended up going to another shop & they cut it & it worked. I then read the key he cut & cut from that & my cut key worked too. So obviously condor mis having trouble reading the original key but is ok with reading the key the locksmith cut......I just dont know why
    attached is a pic of the 3 keys.
    the top one is the original-condor read as 1 3 2 2 3 1 3 5 5 3
    the middle one is the key that condor cut from the original-when I read this in the condor it reads the same as the original
    the bottom key is the one the other shop cut & it reads 3 2 2 3 1 3 5 5 3 3-this opens the door
    I can see that the bittings are all moved up 1 space on the key that works. but as I said, when I read the working key in the condor it reads & cuts ok. I'm thinking there is an issue with the decoding on the condor. can anyone shed some light on this for me?
  3. #183
    Jun 2015
    United Kingdom
    Condor Mini V4.0.1 Update (2017.06.16):
    +Add universal key decode function
    +Add M2-D function
    +Add motor sensor testing function
    *Modify probe/cutter detection
    *Fix machine may crash error problem
    *Fix HU49 key decode error
    *Fix HU66 cutting speed issue
    *Fix BW6 cutting error
    *Fix TBE1 cutting error
    Notes:
    1.New update for both SN KM02/KM03 machines
    2.New function:Main Interface-Key Duplication-Universal Type
    3.Universal Type support decode/cutting parts of home & vehicle keys
    4.Please keep the whole key clean and conductivity good(ensure without dust/oil)
    5.For one side key(thickness of whole key usually 1.5mm or 2.00mm) please add a shim/business card under the key,ensure the whole key thickness should more than 3mm
    condor xc mini v4.0.1 KM02 KM03.txt
  4. #184
    rob h's Avatar
    May 2011
    Use search in D.K. This has been discussed before.
    In your cutting condor menu, you will find more then 1 type of hu64.
    Only 1 is in the decoding section.
    Go look for the hu64 cutting options.
    Get a caliper, and look for the firts and last cut position. So you wil know what type you have.
    Quote Originally Posted by cqae View Post
  5. The Following User Says Thank You to rob h For This Useful Post:
    cqae (17th June, 2017)
  6. #185
    ahhh ok rob, thanks for your reply. You are exactly right, I hadnt looked in that section. Most of the ones I've done prior have just decoded & cut ok, but now I see where I've gone wrong. thanks for your reply
    Quote Originally Posted by rob h View Post
  7. #186
    Nov 2019
    hello guys...
    i need help with the toyota corolla blade i can't find it into the mini condor list
    can someone send me file or info of measurements of the key to add it to the mini condor?
  8. #187
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by avizarisharef View Post
    hello guys...
    it va2t
    to same renault
  9. #188
    Aug 2018
    How to cut va6 blade with condor mini??
  10. #189
    rob h's Avatar
    May 2011
    It is a VA8
    A va6 is 6 cuts, this va8 is with 8 cuts.
    It is in the menu.
    You could use a va2 blade.
    Now pay attention!!!! A to short blade, will not work!
    After cutting, first try blade in ignition lock. Only then you insert it in the remote.
    A original keys, blade holder, is extended, giving some extra room between keycoil, and remote.
    A xhorse or keydiy remote, blade holder, is not extended.
    hello guys...
  11. #190
    rob h's Avatar
    May 2011
    If you have the code, use that.
    Or use the universal duplication option, internal 4 track.
    It works well on these.
    Quote Originally Posted by zeh212 View Post
  12. #191
    Maartinj's Avatar
    Nov 2010
    if anyone need to contact Support / send feedback - here is quick view how to do that
  13. #192
    Nov 2015
    UK
    Rob h
    Please could you advise cut & depth measurements as I would like to make a new profile for my Miracle A5
    Regarding Smart car YM23
    Thanks.
