Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Jun 2010
    Norfolk england
    Default Vag 2015 Lishi pick
    What different with the mk7 golf that the old 3 in 1 wont do.
    Add life to your days not days to your life
    P
    Dec 2010
    Nottingham
    nothing on the pre 2015 built models and some late 2014 models .
    at the end of 2014 vag introduced 3 new locks to their range all 3 locks differ and none are the old HU66 , all center around the HU162 keyway.
    1) the 8 cut version of the hu162 bladed lock was the first to be released on some non proximity key models , initially some golf , ibiza , fabia and polo had this lock fited , this version has 8 straight cuts on an hu162 profile and is a simple pick with the new 8 cut tool.
    2) the 9 cut version was released at the begining of 2015 , this uses the same hu162 blade and profile as the 8 cut , except instead of having 8 conventional cuts as the 8 cut tool , it has just 6 conventional cuts in positions 4 to 9 and 3 side cuts in positions 1 to 3 , 2 cuts will be on 1 profile and 1 cut on the opposite profile , then the 6 conventional cuts , this one ive seen on a 64 plate golf and the golf plus models thus far but has been seen across the non proximity range
    3) the 10 cut vag was released 2015 on models using smart proximity keys on models such as passat , audi tt , A4 , Q5 Q7 etc , this one uses the same hu162 blade but on a reversed profile to the previous 2 new locks , this one also has just 6 conventional cuts in positions 5 to 10 and has 4 side cuts in positions 1 to 4 , 2 on one profile and 2 on the opposite profile .
    both the 9 and 10 cut are a more complex lock to pick , but still straight forward with the 2 new tools , you just feel and pick slightly differently , the new tools work well once you get your head around the feel differences and the side cuts .
    so 3 new locks have replaced HU66 on models from late 2014 . 8 cut , 9cut and reverse profile 10 cut tools.
    but to add some confusion , you will see hu66 on some of this year too , ive done 2015 golf models with 8 cut , 9 cut and hu66 , so as with any cross over year expect to see any of them . and just to add a touch more confusion theres no specific list of which car started using which on the bladed key models .
    to confuse things further on the proximity models , audi decided on the A4 they would recess the lock deeper into the handle , so the 1st 10 cut tool released would not get full insertion on these , so both tool manufacturers had to release a version 2 tool for the 10 cut vag tool amended to overcome the recessed lock on the new a4 models.
    the short answer to your question is that everything has changed , lock , key and tools , but not on all mk7 golf , some up to 2015 still used hu66.
  3. The Following 15 Users Say Thank You to rapidlocksmiths For This Useful Post:
    amigokola (16th September, 2018), AUS-MAN (9th April, 2017), bigkey (5th April, 2017), camelgd (3rd April, 2017), castin (8th April, 2019), fred77 (24th May, 2021), honda1200 (9th April, 2020), Jobeso66 (23rd September, 2018), just4upal (8th April, 2019), nenadgorgi (8th April, 2019), phuckyall (16th September, 2018), purdy (2nd April, 2017), rm23 (21st December, 2018), rob h (3rd April, 2017), subfan (15th September, 2018)
    rob h's Avatar
    May 2011
    Mk7 Golf 2015 uses hu66
    So your question is?
    There are a few lishi called vag2015
    Vag2015 HU162T(10) 2 In 1
    1 2 3 4 side cuts
    4 5 6 7 8 9 10 groove
    1 2 3 side cuts
    4 5 6 7 8 9 groove
    Vag2015 single lever
    12345678 cuts
    Vag2015 twin levers
    12345678 cuts
  5. The Following 5 Users Say Thank You to rob h For This Useful Post:
    amigokola (16th September, 2018), bigkey (5th April, 2017), fred77 (24th May, 2021), just4upal (8th April, 2019), purdy (2nd April, 2017)
  6. #4
    Dec 2010
    Nottingham
    ive seen HU66 , HU162 vag 2015 8 cut and HU162 vag 2015 9 cut on golf models from late 2014/2015 , but ive also seen an hu66 on a 2016 golf , golf plus models ive had plenty on the new 9 cut thus far .
    audi a1 ive done 2016 models still on hu66 , and had a late 2016 A4 on an HU66 profile but have also had a4 on 2015 model using the new recessed 10 cut .
    cross over years will always throw up confusion and all will get seen , but these locks are now out there in abundance and being seen daily .
    the vag 2015 8 cut , both single and twin lift do same job and have same coverage , its down to personal preference which you use .
    the vag 10 cut if you have the gen 1 lock you wont pick open the new recessed locks on the late A4 models using this lock , but you will get the passat , Q range and tt models using this lock , the gen 2 tool does both versions of the lock including the new a4
  7. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
  8. #5
    Jun 2010
    Norfolk england
    Quote Originally Posted by rapidlocksmiths View Post
    Wow anyone would think you wrote the book.
    Sent from my iPad using Tapatalk
    P
  9. #6
    Dec 2010
    Nottingham
    i just like picking and playing with locks , im lucky that i see alot of new vag locks with my contract jobs so get plenty of time with these .
    ive been to alot of late model vag always excited to battle the new locks , often dissapointed to find hu66 on some , from 2015 on its a lottery sometimes on which of them you will see
  10. #7
    rob h's Avatar
    May 2011
    About the new golf plus.
    The door lock is a 3+6
    I can open and read these, but not the ignition.
    Is there a lishi suited for this, like the 8 cut lishi.
    So far, i have not seen the side cuts being in the ignition lock.
    Only the groove part.
  11. #8
    Dec 2010
    Nottingham
    the ignition locks have no side cuts , these are a straight 9 cut similar to the 8 cut tool , thus the key also has conventional cuts on the key in the 1st 3 positions , the side cuts have a relationship to conventional cuts on the 9 cut lock , a number 1 cut on the side cut will have a number 4 conventional cut in that position , a number 4 side cut will have a number 1 conventional cut in that position , side and conventional cut will always be the opposite cut to each other .
    no tool has been made for the ignition as yet , as entry was the 1st priority when the tool was released especially as no one could cut or code these at the time of release.
    once there is a demand for an ignition tool for these then im sure one will be developed , but i doubt this will be until such a time as the vehicles are old enough to have suffered partial lock changes and until such time as locksmiths can cut and program the keys , until then demand for such a tool would be too low for the manufacturers to get payback on their development.
    i see no reason why the current 8 cut tool couldnt be adapted to work on these 9 cut ignitions , as would just take an extra space adding as rest is same , im sure this could also be adapted diy , i will have a play with 8 cut tool on an ignition , as im sure i could pick it with the 8 cut tool in the same way ive been picking the 7 cut va2 lock on new daf vehicles , il have a play and see .
  12. The Following 4 Users Say Thank You to rapidlocksmiths For This Useful Post:
    AUS-MAN (9th April, 2017), bigkey (5th April, 2017), just4upal (8th April, 2019), purdy (3rd April, 2017)
  13. #9
    kemaster's Avatar
    Mar 2010
    BG
    Quote Originally Posted by purdy View Post
    Actually he did. The most comprehensive and descriptive Lishi Guide.
  14. #10
    rob h's Avatar
    May 2011
    Thanks, that is really helpfull.
    Do you happen to know the measerments, so i can try to created a key?
  15. #11
    Dec 2010
    Nottingham
    not to hand , but have them somewhere in workshop from the tools development , il have a look when in workshop
  16. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  17. #12
    Feb 2014
    Hi VAG2015 Lishi pick thread !!
    I did a quick search on here and found this post before I started a fresh thread.
    I'm trying to make sure I have coverage for VAG, currently I have x3 tools
    Mr Li HU66 Generation 1&2 single lifter
    Genuine Lishi HU66 v.2 twin lifter
    Genuine Lishi VAG2015 8 cut single lifter ( night vision )
    I'm somewhat confused TL list a VAG2015 9 cut and a VAG2015 v.2 10 cut. Does their VAG2015 v.2 10 cut cover everything their VAG2015 9 cut does plus overcome the issue of recessed locks ? or do I need both tools for overall coverage.
    Aldridge list Li tools that appear to be marked up differently to the Li tools on 3D .......Help .......What do I need for coverage ??
    And out of the available tools are there pro and cons between Genuine Lishi and Mr Li on these later VAG picks ?
  18. #13
    drugowaz's Avatar
    Mar 2015
    Lithuania
    They all separate 8 9 10 cut.
    Renault ECU tool / IO terminal / A.S.W
  19. The Following User Says Thank You to drugowaz For This Useful Post:
  20. #14
    Mar 2017
    Australia
    Tried and failed to unlock 2018 Porsche Cayenne. The only pick that would insert into the keyway was the 10cut hu162. I had to modify the edge to fit the pick in under the door handle. But when I tried to feel the wafers I could only feel wafers in positions 10-9-8-7.
    I assume my tool wasn’t inserting all the way and this lock requires the v2 tool. I’m looking online to purchase this tool, is there any easy way to spot the difference between v1 & v2?
    In this photo the lishi did go in further than it shows also.
    After looking online, it looks like the gen2 is the pick without the built-in tension lever.
  21. #15
    Dec 2010
    Nottingham
    yup the gen 2 with seperate tensioner not built in is needed
  22. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    Hugh91 (8th April, 2019)
