Results 1 to 15 of 28
    Old Git PaphosAL's Avatar
    Mar 2008
    Default Commando 15.1a for DM500S and DM500C test image
    Hoping that mods or Admin can unSticky the ancient Commando stuff and perhaps run with this new 'fresh start' test release as a sticky, please?
    Cheers- TC
  2. The Following 13 Users Say Thank You to PaphosAL For This Useful Post:
    aliyavuzcan (7th January, 2019), damiensk (4th July, 2015), digicon (22nd May, 2015), ebmitie (15th July, 2015), Hadron (24th May, 2015), khan888 (24th September, 2015), Krusty (4th July, 2015), lfc84 (17th August, 2015), paulallward87 (27th May, 2015), plasterer (21st June, 2015), psats (23rd May, 2015), trance (7th July, 2015), Yosser2000 (30th July, 2015)
  3. #2
    satsmo's Avatar
    Jun 2008
    Done..........Thanks again
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
  4. The Following User Says Thank You to satsmo For This Useful Post:
  5. #3
    May 2009
    Ireland
    1st time user with the Camando image on an Ibox 500s,
    Some issues.
    Can I enable Autobouquet for 2 Satellites, S&Y and C+ Spain? Or if not possible disable autobouquet all together so they don't update as might delete the 19e channels.
    Also how can search stations from 2 satellites 28E and 19E, what I did is enable Diseqc, after selected 28e as 1 and 19E as 2 on Diseqc settings, then Scroll down and selected on the satellites 19e and did scan now, I can see it finds stations but after I cannot find them anywhere to view them, is there a way to see all channels?
    I think because I have the autobouquet maybe they are not saved, but not sure.
    I also tried to check the channel list with DreamboxEdit, but not sure what the paths are for
    "Services and Bouquets Files", "User Bouquet files", "Satellites.xml file" alos asking for "Path for Picons" I have all with "/var/etc/" but get errors when trying to receive from Receiver.
    Is there another image that might be better for an Ibox 500s?
    If I should post anywhere else please let me know.
    Thanks in advance
  6. #4
    Jul 2014
    Liverpool
    Quote Originally Posted by PaphosAL View Post
    Cheers- TC
    Thanks for this mate all seems great, only problem auto bouquets doesn't sort +1hr in its own bouquet even down its selected to Yes, any ideas
    Paul
  7. The Following User Says Thank You to paulallward87 For This Useful Post:
  8. #5
    birmingham
    Quote Originally Posted by paulallward87 View Post
    Paul
    same problem here , when will the new update release this image does not realy scan
  9. #6
    Apr 2013
    For some reason I am now not getting the movie channels - is there something wrong ?
    John.
  10. #7
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by jonnyboy123 View Post
    John.
    Most of the movie channels have changed frequency either add a new bouquet or scan the transponder in manually.
    Frequency 11934
    Fec 5/6
    Vertical
    Symbol Rate 22000
    Andy
  11. #8
    how do I scan a channel manually ie cant get btsportespn. Like the image a lot. Just loaded it today after a long absence and very pleased with it but having to learn.
  12. #9
    Quote Originally Posted by ebmitie View Post
    Just an update I did a few scans using autobouquets and eventually btsportespn appeared and I added it to sport bouquet.
  13. #10
    Mar 2012
    Great image but one big thing missing for cable users cant mention it here but cc fine for sat users but mg needed for cable users mostly?
    cant get it going back to jade dont want to?
  14. #11
    Mar 2012
    done it unsure what i did but many thanks its going now bouquets brilliant
  15. #12
    Junior Member Duall's Avatar
    UK
    Is this worth the update from 15d
  16. #13
    Hi I'm using this image and it's been great but the other day I lost the movie channels on mine and my dads boxes. Have they moved? or is there a way to scan to get them in again and if so on what frequency.
    Also is there a way to view an all channels list on this image? I get all the categories but can't find how to view "all channels".
  17. #14
    Aug 2008
    does autobouquets allocate the bt sport interactvie channels in to their own bouquet like sky sports interactive on 15.0d ?
    BT Sports Extra 1 - 11082 H 22000 5/6
    and
    2 (53220)
    3(53230)
    4(53240)
    5(53250)
    6(53260)
    11344 H 27500 2/3
  18. #15
    UK
    Press yellow for full channel list
  19. The Following User Says Thank You to Duall For This Useful Post:
    lfc84 (15th September, 2015)
