Page 106 of 290 FirstFirst ... 65696101102103104105106107108109110111116156206 ... LastLast
Results 1,576 to 1,590 of 4348
Thread: VVDI PROG
  1. #1576
    Apr 2015
    Quote Originally Posted by automotrizVIP View Post
    THESE NEW ADAPTERS,
    with this it eliminates my problem?
    my programmer does not read any eeprom after version 4.4.8----
    friend,let me check your device photo,i will try my best to solve your problem.
  2. #1577
    Apr 2015
    Quote Originally Posted by hipolitogt View Post
    I know... But what can I do if original wires are WEAK? I had to repair the cable the second time I used it...
    Enviado desde mi SM-G955F mediante Tapatalk
    you can replace it use a normal wire,but the length should be same as or shorter than the original wire.
  3. #1578
    Oct 2015
    Soviet Union - USSR
    Hello dear Members. any one try read 908 motorolla 0L02M and 1L02M with last update?
    before Update I damage the MCU.
    Today with last update and modify Reflash cable DAMAGED again. I can read and write that MCU but EIS cant work, if I understand right damaged some port in MCU. last time I fix EIS bug - change 1L02M from donor EIS and write EEProm by Orange.
    carefully who will work
  4. The Following User Says Thank You to exSPEEDyTOR For This Useful Post:
    bearheroes (25th October, 2017)
  5. #1579
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by exSPEEDyTOR View Post
    you mean motorola in mb vito 639?
    i read may be 20 time all time ok.work for me 100%
  6. #1580
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Hi all friends
    VVDI-Prog can read this EIS ?
    W221
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  7. #1581
    Jun 2016
    Moldova
    Hi. vvdi prog does not read this ezs.
  8. #1582
    Moderator
    PremierD's Avatar
    Jun 2009
    I think that you will find that nothing can read that MCU .. but hay ho .. I have been known to be wrong ...
  9. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    CarCity (26th October, 2017), clearly (1st November, 2017), mickye_dj (28th October, 2017)
  10. #1583
    Oct 2014
    hi, today unlock astra h key with pcf7941, but has anyone dump for key? the chip is now blank, i need to precode the key. regards
  11. #1584
    ibratex's Avatar
    Jul 2015
    angola
    Hello ...
    i am trying to blank pcf7952 but the last string in the erom is not changing ... in my case its always A5 last string .... i am trying to write dump for but verify error ... also in eeprom few string in 1st line and few string in last line veeify error ... i am wrting onboard because pcf adapter not detecting chip ... what to do please
    Sent from my SM-G935F using Tapatalk
  12. #1585
    Apr 2015
    Quote Originally Posted by ibratex View Post
    Hello ...
    yes,because this chip designed the last some bytes (2 or 4) cannot be changed, and these data can only read, that's why you rewrite the dump and verify error.
    after you rewrite,no need to verify,you can read data again and then compare by yourself. if dump is correct,usually after rewrite you can use it directly.
  13. The Following 4 Users Say Thank You to Samic For This Useful Post:
    csavargo2 (20th March, 2018), daxxer (30th October, 2017), ibratex (27th October, 2017), PremierD (27th October, 2017)
  14. #1586
    Apr 2015
    VVDI PROG latest software V4.6.4 version update
    v4.6.4 (2017-10-26)
    * This version DON't need update firmware
    * Fix some bugs
    + Add VVDI PROG USER MUNUAL 4.6.4 version in Doc folder
    * Fix EEPROM CLIP ADAPTER R&W some chips error problem
    + Add LACROSSE-BCM(2008) option in <4-IMMOBILIZER>-><BUICK>
    + Add IMMOBOX(STM8AF5268),IMMOBOX(STM8AF6268) options in <4-IMMOBILIZER>-><TUNGTHIH>
    + Add ALSVIN-V7(2017) option in<5-DASHBOARD>-><CHANGAN>
    + Add HAVAL-H6 option in<5-DASHBOARD>-><GREATWALL>
    + Add E60-KBM, PDC-MODULE options in <8-OTHER>-><BMW>
    Notes: please download and keep using the latest software version, any problem post here/PM me.
  15. The Following 11 Users Say Thank You to Samic For This Useful Post:
    AndyCZ (7th November, 2017), CarCity (27th October, 2017), damih (27th October, 2017), daxxer (30th October, 2017), derdud (27th October, 2017), habbyb (30th October, 2017), keyantic (27th October, 2017), Maartinj (27th October, 2017), polys123 (1st November, 2017), sniegavirs (27th October, 2017), sv2hqx (27th October, 2017)
  16. #1587
    Oct 2014
    Quote Originally Posted by niku202005 View Post
    hi samic, any ideea where i can take the eeprom content for pcf7941 opel astra h key? i look all the internet and no success
    thank's
  17. #1588
    Feb 2016
    hello guys. be careful with BMW EWS4.4. i did read eeprom from a ews4.4, eeprom did saved okay, but after that i did read flash and while reading flash, eeprom was messed up. Car did not started, ews communication was ok but no vin no key number. after that i write eeprom back, and car starts.
    So keep in mind. always read EEPROM and do backup and only after that read FLASH on this one....
    +thanks if I helped you!
  18. The Following 2 Users Say Thank You to tibibond For This Useful Post:
    Levanime (29th October, 2017), polys123 (1st November, 2017)
  19. #1589
    bearheroes's Avatar
    Dec 2011
    thank's
    Buy them...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  20. #1590
    Nov 2015
    Where from???
