i also have same problem cannot read cas3+ 0l15y i use r270 to read succesful.
Anyone has success with M35080/D80 adapter? M35080 6 Chips are not even recognized ("chip not connect"), while without the adapter readig works fine. Tried with different vcc settings.
Is there a hardware patch for this?
So buying this aapter didn't take me any further..
igorr (20th January, 2018)
Also, on the pcb there is a high freqency transmitter ic, with built in mcu. Does averyone have this chip on the pcb?
http://www.hoperf.com/upload/rf/RFM60_en.pdf
sniegavirs (20th January, 2018), ZanBre (5th February, 2018)
External power i guess is needed for some pcb's because of other component power consumption...
lalaina74 (21st January, 2018)
Samic, its possible to add Renesas R5F64524 R32C mcu ?
Now silly thing. 24c02 b58328 from old vag ecu. Vvdi reads OK but cannot write Done with xprog and to confirm with carprog It is little scarry, device which reads cas4 (done few, all success) cannot do such easy thing
MB - Sprinter
ECU connection
ISP1= DSO or TDO or MISO or PGD
ISP3=RESET or TMS
ISP6= XMEGA PDI
ISP9=MCLR ( 13v for PIC )
ISP10= GND
12V = pin2 connector KA + pin4 connector KB
GND = pin8 connector KA
For other connection and ori file tell to me .
Best Regards
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
