Page 137 of 290 FirstFirst ... 3787127132133134135136137138139140141142147187237 ... LastLast
Results 2,041 to 2,055 of 4348
Thread: VVDI PROG
  1. #2041
    MC9S12XEP100 - 1N35H UNSECURED - work without external power but cant detect d-flash size - giving messtge partition corrupted
  2. #2042
    habbyb's Avatar
    Romania
    Quote Originally Posted by djjazzer View Post
    Maybe this board is not supported by VVDI Prog? Had to use Smok diagram for reading. EIS is 2115452308
    Sent from my ASUS_Z00AD using Tapatalk
    identic part number ezs read today ok with vvdi prog ,really smok did not read bat vvdi prog ok
  3. #2043
    Oct 2017
    Quote Originally Posted by habbyb View Post
    Reading wasn't problem. After reading, EZS dead, I think flash corrupted. What mask you read it under?
  4. #2044
    habbyb's Avatar
    Romania
    That's what I read successfully .
  5. #2045
    May 2013
    Common problem with these type EIS to get the flash corrupted when read eeprom. Search on the net for the flash files. You will find a collection of different ones. The 209 and 211 numbers work in each other places from my own experience!
  6. The Following 3 Users Say Thank You to obeids For This Useful Post:
    lalaina74 (22nd February, 2018), PierreTheron (7th March, 2018), ZanBre (23rd February, 2018)
  7. #2046
    May 2013
    Quote Originally Posted by sniegavirs View Post
    VVDI Prog is great for CAS4! It is not tools fault that you obeids were not careful enough doing your job. And with correct PFlash and DFlash your Cas4 could be working again but that depends only on you yourself. I have done around 11 CAS4 at the moment and never had any problems!
    Problem was the faulty Cable / Harness of 9S12 MCU reading which connects on VVDI. Some cables where internally loose / broken.
  8. #2047
    New test:
    1. MPC5607B 0N69H - readed correctly with external power
    2. MC9S12XEQ512 3M25J - Unsecured - read with external power - but give partition error so must manually set dflash/eee size
  9. #2048
    This is really problem for you to connect external power? Simply, it is much more save to read with ext power. In every programmer.
  10. The Following User Says Thank You to EMCE159 For This Useful Post:
    hipolitogt (24th February, 2018)
  11. #2049
    igorr's Avatar
    Aug 2010
    Quote Originally Posted by gif_kuba View Post
    New test:
    yes
    mc9s12xep768 nead also to manually set d-p flash xprog do it it self, it can be confusing
  12. #2050
    wissamshaat's Avatar
    Oct 2017
    france
    hello everyone
    any pinout for sirius32 renault??
    thank you
  13. #2051
    Mar 2017
    I have tried everything to read ST95320. Clip on board...did not work. Also tried reading it as Atmel 25320...nothing. Removed from board and put into sop8 adapter. Does not work. Do I have to select another chip? Using 4.6.7
    Read chip fine with another tool. But other tool freezes when I try to write data.
  14. #2052
    Feb 2016
    Quote Originally Posted by ps80l View Post
    sop8 adapter works fine but it s not safe to read/write by clip......
    +thanks if I helped you!
  15. #2053
    Mar 2017
    You did not answer my question... Unless both of my sop8 spring adapters are bad...
  16. #2054
    Cardiag.ru's Avatar
    Russia
    VVDIProg is damaged. Think on pin1 zif socet as was with one of my buyer. VVDIProg was sent to exchange on factory.
  17. The Following 2 Users Say Thank You to Cardiag.ru For This Useful Post:
    ps80l (26th February, 2018), taxo1965 (25th February, 2018)
  18. #2055
    Quote Originally Posted by EMCE159 View Post
    in most cases is not problem, i write only my test results,
    in original xprog-m i never use external power
