You had many good advices. Do not hesitate to press "Thanks" (reputation buttons)
"thanks" if i helped you is really appreciated
ok reset to 0, but with what? vvdi prog? Or is it necessary to have another tool to reset the file ????
Now reading is ok but i can't write. I'm trying with CLR Protect but also without success
THANKS THANKS
alclot (22nd September, 2018)
PLEASE SOMEONE can respond !! ok reset to 0, but with what? vvdi prog? Or is it necessary to have another tool to reset the file ????
For cas read with vvdiprog , save the dump, put the dump here some one will make it for u, or search in digital kaos for R270 SOFTWARE install it then load your dump to it, put the value you need, save a new dump. Load to vvdiprog, write it with vvdiprog, done, 1 minuet job.......!!!
Sent from my HTC U11 using Tapatalk
Actions speak louder than words
pierre renault (23rd September, 2018)
ttzag
OK, that's all I wanted to know, vvdiprog has no mileage calculator.
Thank you
mickye_dj (23rd September, 2018)
forklift driver.. why?
pierre renault (23rd September, 2018), trinicolin (24th September, 2018)
Hi, I'm thinking of buying vvdi prog, because I already had problems with cas3 + 0m23s with DP3. It was just information.
Thank you all
