VVDI PROG - Page 180
Page 180 of 290 FirstFirst ... 80130170175176177178179180181182183184185190230280 ... LastLast
Results 2,686 to 2,700 of 4343
Thread: VVDI PROG
  1. #2686
    Apr 2015
    Quote Originally Posted by obeids View Post
    Hi there
    Is there a missing diagram on the VVDI prog?
    I have done many W209 / W203 ignition which have mark on PCB ( 209 ZGW ). I find 2 types of diagram on VVDI prog. However the chip selection is wrong. 90% of those that I have done had 3L40k / 4L40K / 5L40k. The pin connections are the same but chip ID differs. Currently only show 1L59W and some other one. If you select those that are in Menu under IMMO -> BENZ then it doesn't read or reads corrupt.
    GO to MCU and select the matching Mask for 4L40K and it will read using the same diagram of W209 9S12 ST12.
    So please add this mask in the option when select that Immo.
    Thanks alot
    Thanks for your feedback, still finding EIS and try to find the caused reason.
  2. #2687
    Basti13's Avatar
    UK
    Quote Originally Posted by p1et View Post
    Post picture. We can't see anything.
    Now you can see .
    NO PASS
  3. #2688
    HIC's Avatar
    Hi everybody
    I am a new buyer for VVDi prog;i recieve my package yesterday;all is OK.
    I m going to try it in the evening.
    Best regards
    H.E
  4. #2689
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Hi all Friends
    I need to read FRM3R E70 VDM D-Flash
    But VVDI-Prog not detect automatically D-FLASH and EEE memory size ?
    what process I should try ?
    Thank for your advance
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  5. #2690
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by CarCity View Post
    Hi all Friends
    What is the MCU?
    One i was reading a while ago is D-FLASH 32KB and EEE 4KB
  6. The Following User Says Thank You to sniegavirs For This Useful Post:
    CarCity (13th November, 2018)
  7. #2691
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by sniegavirs View Post
    What is the MCU?
    MCU : MC9S12XEQ384
    I read that :
    Corrupt D-Flash file detected! Results probably incorrect!
    VIN: WBAFG8100DL28****
    Production date: 12.12.2012
    Programming date: ff.ff.ffff
    HW-NR: 9206234 (Hardware part number)
    SW-NR: ffffffffffff (Updated part number)
    ZB-NR: ffffffffffff (Original part number)
    S: 9287252 (Original part number)
    and now need to repair this :
  8. #2692
    sniegavirs's Avatar
    Mar 2017
    Latvia
    MCU : MC9S12XEQ384
    I read that :
    As far as i understand for this MCU it is possbile to have D-FLASH and EEE in partitions.
    But if for example: if D-Flash is 32KB then EEE is 0KB or if EEE is 4KB then D-FLASH is 0KB and of course full P-Flash. Correct me if i am wrong..
    And for this MCU being used in BMW FRM modules it is P-Flash with EEE 4KB and no D-Flash(0KB) In VVDI Prog menu you can select under 8-OTHER->BMW->FRM-E-SERIES-XEQ384 and there is only EEE and P-FLASH options to read.
    You should read EEE as 4KB and forget about D-Flash. If your EEE is corrupted i might not be able to help but i have files from 2012 E71 FRM XEQ384 EEE 4KB and P-FLASH.
  9. The Following User Says Thank You to sniegavirs For This Useful Post:
  10. #2693
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Thank you so much
    Can you give me that files ?
  11. #2694
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Thank you so much
    One is from my own read FRM but i don't have inf about HW and SW numbers but it is from 2012 E71.
    Other file is from my FRM file collection that i got somwhere..
    Good luck mate!
    P.S. Please ignore that D-FLASH file in one of the rar's
  12. The Following 2 Users Say Thank You to sniegavirs For This Useful Post:
    CarCity (13th November, 2018), serikpay (1st July, 2023)
  13. #2695
    Oct 2017
    Hungary, Budapest
    MCU Reflash Cable V3
    Hi guys, I would like to read/write an ST10F269 with my VVDI Prog, but bit confused now.
    Connection Diagram got an "Important!!!" tab, which titled as : MCU Reflash Cable V2 modified to V3, which about to modify cabling and remove resistors.
    ST10F269 tab says use MCU Reflash Cable V2
    Originally I have MCU Reflash Cable V3, but the cabling and other parts also looks same as the unmodified V2 which needs some costumisation by the Important tab.
    So my question is that, should I modify my factory V3 cable as V2 > V3 or can use it "as factory" V3 and just solder to MCU ?
    Sorry if hard to understand
  14. #2696
    Jul 2008
    romania
    u can use v3
  15. The Following User Says Thank You to mickye_dj For This Useful Post:
    kaleval (14th November, 2018)
  16. #2697
    lion0304's Avatar
    Oct 2014
    Default Hyundai I30 KEFICO 39122-2B122 Pinout
    ECU with gear box integred MCU ST10F275
    **** Revised complet pinout ***
  17. The Following 6 Users Say Thank You to lion0304 For This Useful Post:
    alclot (19th November, 2018), damih (16th November, 2018), Perryking (15th November, 2018), PremierD (16th November, 2018), sqlkarol (16th November, 2018), taxo1965 (18th November, 2018)
  18. #2698
    Quote Originally Posted by Samic View Post
    did you connect 1KΩ resistor between DUOUT and VCC? if not pls do. if so, but still not work. please setting software voltage to 4.2V then try again.
    yes, have connected 1kohm resistor, tryed with vcc from 3,5V to 4,5V and still have message "chip not connect"
  19. #2699
    MCU : MC9S12XEQ384
    I read that :
    Here repaired EEE
  20. The Following User Says Thank You to gif_kuba For This Useful Post:
    CarCity (17th November, 2018)
  21. #2700
    Feb 2011
    PL
    VVDIPROG
    Chrysler Occupant Classification Module connection
    MC9S12DG128_Secured
    3L40K
  22. The Following 4 Users Say Thank You to sqlkarol For This Useful Post:
    lalaina74 (17th November, 2018), lion0304 (17th November, 2018), Perryking (19th November, 2018), PocketHero (17th November, 2018)
