Samic,
Could not find N54(MSD80) in ecu list
do you plan to add it?
Samic,
ibratex (13th January, 2017)
weza247 (24th January, 2017)
VVDI PROG latest software version V4.5.4 update
v4.5.4 (2017-01-17)
* This version DON't need update firmware
* Fix some bugs
+ Add VVDI PROG USER MUNUAL 4.5.4 version in Doc folder
* Update polish support, select in Language option
+ Add X5043,X5045 options in<1-EEPROM&FLASH>-><XICOR>
+ Add diagram in <2-MCU>-><FUJITSU-MB91F>
+ Add HC908LK24, HC908LK24_SECURED options in <2-MCU>-><MOTOROLA-MC69HC(9)08>
+ Add MC9S12A32_UNSECURED,MC9S12B64_UNSECURED,MC9S12B128 _UNSECURED, MC9S12B256_UNSECURED,
MC9S12D32_UNSECURED,MC9S12A32_SECURED,MC9S12B64_SE CURED,MC9S12B128_SECURED,MC9S12B256_SECURED,
MC9S12D32_SECURED options in <2-MCU>-><MOTOROLA-MC9S12>
+ Add MT80(TC1766) option in <3-ECU>-><DELPHI>
+ Add MED17.5(TC1766) option in <3-ECU>-><VOLKSWAGEN>
+ Add diagram-V2 in <4-IMMOBILIZER>-><BENZ>->EIS-W220(W215)(1J35D),EIS-W220(W215)(1J74Y),EIS-W220(W215)(2J74Y),
EIS-W220(W215)(3J74Y),EIS-W220(W215)(4J74Y) options
+ Add EIZ-W230(ST12) option in <4-IMMOBILIZER>-><BENZ>
+ Add SAICMAXUS-RV(2014) option in <5-DASHBORAD>-><SAICMOTOR>
+ Add REAR-SAM-W212 option in <8-OTHER>-><BENZ>
Notes: please use latest software version,if not work/find bugs post here/PM me.
CarCity (17th January, 2017), damih (20th January, 2017), daxxer (17th January, 2017), dmp (17th January, 2017), dorofteius (17th January, 2017), duplikeytor (17th January, 2017), grzyb26 (2nd February, 2017), HeXeN (17th January, 2017), ibratex (17th January, 2017), kazikk (17th January, 2017), keyantic (17th January, 2017), lidons (17th January, 2017), Maartinj (17th January, 2017), Nassreddine84 (17th January, 2017), rob h (17th January, 2017), rola1971 (17th January, 2017), solitaire (17th January, 2017), ttzag (17th January, 2017), vasiliev7719 (20th January, 2017), weza247 (18th January, 2017), ZanBre (5th February, 2018)
Hi samic when will u activate the renesas option R5F
NO ADVERTISING PLEASE
Samic , can i have a diagram to read ISM & 7G with vvdi
There are 2 versions for Land Rover RFA module.
1 is unsecured and 1 is for secured.
Both the PCB's look identical as do the mask sets.
How can you tell which version to use?
try read like unsecure, if you can`t read then you have secured mcu.
I confirm what he wrote "micromax".
Read as unsecure, does not read- read as secured.
Do not stress, do not erase.
Hi Samic,
Motorola HC12D60 1L28M not read, tested on AIRBAG VW62 1T0909605C and Dash Ford Mondeo MK3.
Somebody had any problems reading 95160 eeprom or any other ST SPI memory ? i all read 000000000
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
Hello --bursuc--
With all due respect, carefully check the connections.
I checked for version 4.5.4 and works.
Did you notice where the pin number 1 in the programmer.
Check paw 1 of the EEP. Reverse in the socle. Some vvdiprog of the first one the indicator sticker was put upside down indicating badly the position 1
excuse my English, is the best.
bursuc (24th January, 2017)
