Page 102 of 290 FirstFirst ... 25292979899100101102103104105106107112152202 ... LastLast
Results 1,516 to 1,530 of 4350
Thread: VVDI PROG
  1. #1516
    Dec 2015
    LITHUANIA
    Wire are ok, I have second cas and it read without any problems.
  2. #1517
    Jan 2013
    how to read bsi on citroen c2 1.4hdi bsi is valeo 9659285480
  3. #1518
    Oct 2017
    Is there a change that VVDI prog can do ST 35160WT?(erase first 2 lines)
  4. #1519
    Nov 2012
    Quote Originally Posted by fytfh View Post
    Search for 95128. Even ponyProg can do that.
  5. #1520
    Nov 2015
    Today I recieved my new VVDI Prog. Unfortunately my first experience wasn't a positive one. I'm trying to read a MC68HC912D60 from a jaguar x-type dash and it cannot do it. I'm using the connection diagram in the programm. Any idea???
  6. #1521
    Default VVDI PROG
    No. Vvdi prog not supported this mcu...
    I tried many many times on Ford dashboars.
  7. #1522
    Nov 2015
    Sorry for that, I've just succeded reading the chip. The scheme in NYO4 is wrong, the RESET and BKGD are inverted! Regards!!!
  8. #1523
    When i have a 8 leg soic chip, i always tey wich row i jave to place it. Like 24c04, 95cxx.5P08.. is the an document explaining wich chip is on wich row?
    Verstuurd vanaf mijn SM-G920F met Tapatalk
  9. #1524
    Nov 2015
    Any row in the SOP8 area
  10. #1525
    Quote Originally Posted by stefyhgs View Post
    Thats not true. For example, 24c04 does not work in the first row, but will work on the second row. And if you look closely, you see the connecting lanes are diverent by row.
  11. #1526
    Apr 2009
    RS, BRASIL
    in mine are all the same friend
  12. #1527
    kevfield's Avatar
    uk
    @stefyhgs
    what MASK is your mcu vvdi prog should read this no problem
  13. #1528
    I will take a picture tomorrow to explain what i mean.
  14. #1529
    Sep 2015
    Botswana
    Default BMW E90 ECU
    hie guys
    is it possible to get isn from bmw e90 2006 using vvdi prog
  15. #1530
    Nov 2015
    It is a 0L26M. But read/write with no problem, once I connected it the right way.
  16. The Following 2 Users Say Thank You to stefyhgs For This Useful Post:
    kevfield (15th October, 2017), smokinjoe (21st August, 2020)
