Page 103 of 290 FirstFirst ... 353939899100101102103104105106107108113153203 ... LastLast
Results 1,531 to 1,545 of 4349
Thread: VVDI PROG
  1. #1531
    kevfield's Avatar
    uk
    Quote Originally Posted by LEORNARD NKATA View Post
    hie guys
    is it possible to get isn from bmw e90 2006 using vvdi prog
    no
    Thanks Kev
  2. The Following User Says Thank You to kevfield For This Useful Post:
    LEORNARD NKATA (15th October, 2017)
  3. #1532
    Sep 2015
    Botswana
    Quote Originally Posted by kevfield View Post
    no
    Thanks Kev
    which tool shuld i use on the table car is far from me
  4. #1533
    May 2011
    hi
    is there any comparision between VVDI prog with upa ,xprog,orange etc...like can i use VVDI prog as incircuit programmer and airbag module programming for renesas and fujitsu mcu programmer....???/
  5. #1534
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by digimile View Post
    hi
    simple download VVDi PROG software, select MCU / CPU what ever you want (see a list) and check connection diagram
  6. #1535
    Nov 2015
    As far as I could see is the most complete of the programmers that I currently own. I have Carprog, X-prog, Upa, Minipro and now VVDI Prog. I didn't test it so much but it promisses alot. Regards!!!
  7. #1536
    Apr 2015
    VVDI PROG latest software version V4.6.3 update
    v4.6.3 (2017-10-17)
    * This version DON't need update firmware
    * Fix some bugs
    * Fix MC68HC(9)08 series problem
    + Add AM29F200BB-xxE, AM29F200BB-xxF, AM29F200BB-xxS, AM29F200BT-xxE, AM29F200BT-xxF, AM29F200BT-xxS, AM29F400BB-xxE,AM29F400BB-xxF, AM29F400BB-xxS,
    AM29F400BT-xxE, AM29F400BT-xxF, AM29F400BT-xxS, AM29F800BB-xxE, AM29F800BB-xxF, AM29F800BB-xxS, AM29F800BT-xxE, AM29F800BT-xxF, AM29F800BT-xxS, AM29F160BBxxE,
    AM29F160BBxxF, AM29F160BTxxE,AM29F160BTxxF options in <1-EEPROM&FLASH>-><AMD> (Need AM29FXXXB ADAPTER)
    + Add M95M01, M95M02 options in <1-EEPROM&FLASH>-><ST>
    + Add M95M01(CLIP), M95M02(CLIP) options in <1-EEPROM&FLASH>-><ST(CLIP)> (Need EEPROM CLIP ADAPTER)
    + Add RFA-UNSECURED(MC9S12XET256), RFA-SECURED(MC9S12XET256) options in <8-OTHER>-><LANDROVER>
    Notes: please download and keep using the latest software version, any problem post here/PM me.
  8. The Following 10 Users Say Thank You to Samic For This Useful Post:
    AndyCZ (19th October, 2017), CarCity (17th October, 2017), daxxer (18th October, 2017), dorofteius (17th October, 2017), electronistul21 (18th October, 2017), keyantic (20th October, 2017), lush29 (17th October, 2017), sniegavirs (18th October, 2017), ttzag (18th October, 2017), weza247 (18th October, 2017)
  9. #1537
    Dec 2015
    LITHUANIA
    Can we unlock BMW E keyless key with 5wk49143 using vvdi prog?
  10. #1538
    Apr 2009
    RS, BRASIL
    how to buy 29fxxx adapter?
  11. #1539
    spychu14's Avatar
    May 2011
    POLAND
    Is it possible to add SAK-XC164CM-16F20F ?
    Or can i read it with option XC164CS-16F ?
    It has different pinout because it have only 64pins.
    Checked - cannot read as XC164CS.
    VAG
  12. #1540
    Apr 2015
    Quote Originally Posted by spychu14 View Post
    friend, cannot support read XC164CM.because XC164CM is different between XC164CS. XC164CM lack of some signal control PIN if compare with XC164CS.
    we will do some research and check again.
  13. The Following 3 Users Say Thank You to Samic For This Useful Post:
    CarCity (18th October, 2017), spychu14 (18th October, 2017), yugo45 (19th October, 2017)
  14. #1541
    Apr 2015
    Quote Originally Posted by Deimis View Post
    Can we ulock BMW E keyless key with 5wk49143 using vvdi prog?
    you can try to use VVDI PROG 79xx adaptor directly,mostly of PCB it can work.if cannot renew success let me know, we can update.
    by the way,if any other key users need to add on VVDI PROG renew remote function,please post here, we will check and try to add.
  15. The Following 3 Users Say Thank You to Samic For This Useful Post:
    bry0sb (7th January, 2018), CarCity (18th October, 2017), csavargo2 (20th March, 2018)
  16. #1542
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  17. #1543
    foxtec800's Avatar
    Can Vvdi prog read W639 eis R1 in circuit ? Has anyone a connection diagram for this, R2 is listed for Immo mcu but nothing for R1 mileage
  18. #1544
    electromech's Avatar
    Behind a large rock
    Quote Originally Posted by Samic View Post
    Could you please add the dumps as you have in the VVDI KEY TOOL so we can also renew keys with the VVDI PROG
  19. The Following 5 Users Say Thank You to electromech For This Useful Post:
    bry0sb (7th January, 2018), CarCity (18th October, 2017), mickye_dj (20th October, 2017), sniegavirs (18th October, 2017), taxo1965 (10th February, 2018)
  20. #1545
    Jan 2017
    Samic. Can something be done with the BMW E series key on the PCF7944AT? Can you add to VVDI prog?
