bearheroes (6th November, 2017), sniegavirs (6th November, 2017)
Hi Samic, here is log file. Thanks
What is the original site of XHORSE company?
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
ALEX65 (7th November, 2017)
one question
whay when I want to reset astra H corsa D I must rest protection as 7961 and write as 7941
keys work ok.but yust want to know
Yes. I am doing-it the same way, otherwise it cannot reset.
But yes, key working good.
igorr (6th November, 2017)
mickye_dj (6th November, 2017)
Xhorse company is like a ghost ;-)
Remote renew and program Xhorse Key successfully.
https://youtu.be/6JJ4xWRF8WU
has someone tried read MEVD1723 with vvdi prog?
I would be nice to have a calculator and a connection diagram for some rcd's.
Like rcd 310 blaupunkt. I read nec with smok and eep with VVDI.
It work;s with vvdi also probably, but it is faster with smok, as I have a conection diagram .
Maibe tomorow I will try to make a diagram and send to X-horse support.
Cause I have like 9 units to do right now.
mickye_dj (7th November, 2017)
RCD calculator is the last thing VVDI needs...
igorr (7th November, 2017)
If You are a good one, then you have smok, orange, upa, x-prog and the rest.
At least with the rcd it will do some good.
