I've tried using the M3080/D80 special adapter and the 16 pin spring loaded socket selecting appropriate option.
Both times it, once click erase inc it shows on bottom "trying" with a percentage next to it, then i end gives the error message.
need some help regarding about delphi immo read ..... i useing the vvdi prog ... follow all the diagram.. i can read out the file ... but i cant do the pin calculator...when i do the pin calculator .. it show me file format error
shilow1989 (30th September, 2018)
WRX 14 (29th September, 2018)
Ok, on adapter i tried with the spring socket and by solder. Both times gives the crack error, so not sure why it isn’t working. I have some opel corsa d dash here, maybe tonight i’ll try with one-off those and see what happen.
I’m not really sire exactly how that area is secured maybe its something
To do with being from BMW why not working, if they have some secure code or something.
I've just removed 080DOWQ from corsa D inst cluster and using adapter it read ok, and erase inc worked ok too. Gives status in bottom box saying crack success, So i guess with VVDI prog there is some problem in cracking BMW chip.
comizelu (30th September, 2018)
erm... hi all i would like to ask... how to update this tools?? i though this tool no need to update .. u just need to install the software then everything should be ok.... but pass few day i try to read out the file for delphi 48 immo ... keep reading error... and i bring it to mine friend to read it out whit his vvdi prog his reading everthing is ok....but mine tool reading is eror... i just bought this tool recently and dunno how to update it.. and i download the software online .. 4.7.4 i open that program upper right got a logo for update ... i press it and wait for so long ...is just show comunication with server fail(3)...
No, the manufacturer occasionally releases software updates to make improvements / add more functionality / fix bugs etc...
Personally i'e never actually used the upgrade function in VVDI prog software. When new software is available the download link is usually posted into the forum.
With other VVDI tools the update function is no good, and have to use the "Xhorse upgrade kit" software to update the device firmware where it's necessary (the computer software update details will tell you if a device firmware update is actually required) - i've not got a link readily available for downloading this but chances are you'll find the link on our sellers website.
I think V4.7.4 is latest software anyway, unless new version released i the last week or so.
What version software is your friend using? It may also new worthwhile asking your friend to help guide you how to update the software. May be easier being shown practically.
Have you tried the device with any other chips, is it working ok? All your solder connections were good?
shilow1989 (1st October, 2018)
Hello Guys!
I have a vvdi prog over 1 year or more, now just faced with the "Device error, please check USB driver".
Only red led stays on, nothing more.
I used the device on both my laptops before without any problem, tried to change drivers and so on, nothing seems to help, i have even tried to update firmware as a last chance but after update file 2 starts update fails.
somebody know what the hell i should do to make this thing working again?
Thank You!
Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
