lion0304 (1st November, 2018)
@SamicI do not know what kind of information you need.D70F3239 is possible to do it with Orange and I use the same IN-circuit of the VVDI2, modifying the DB15
adapter orange5 ccdi2 BCM.jpgIMG_20180905_181718_2602.jpgIMG_20180905_182548_7285.jpgIMG_20180905_193651_9514.jpg
but the file that Orange5 throws is EEP and Flash (separated) and is not supported by VVDI2 **error. I said before 70F3229 and correctlys is 70F3239
excuse my English, is the best.
Some readed files are crypted before saving by orange but those are looking good.
If you verified the reading and always the same then vvdi2 using wrong decryption (btw miraclone too)
i think it's a good idea when you send an issue ticket with this files to vvdi support
Xhorse technical support http://www.xhorse.uk/issue/
Dear friend, @Samic, I see that you always giving the best of the equipment and updating for the needs of the users, Since they are in the subject of updating with more Devices, I ask you please that you intend to update Infineon Tricore Future TC2 ××× , are located in new Airbag Modules.
Read/Write Data Flash
Read/Write Flash
TC22xx-12F Data Flash 64 KB
TC22xx-16F Data Flash 96KB
TC22xx-24F DataFlash 128KB
TC23xx-24F Data Flash 128KB
TC23xx-32F Data Flash 128KB
TC22xx-12F Flash 0,75MB
TC22xx-16F Flash 1MB
TC23xx-16FFlash 1MB
TC23xx-32F Flash 1,5MB
TC23xx-32F Flash 2MB
It would be very appreciated. your friend Automotive VIP, I would appreciate
WINNER THE LOSER
taxo1965 (2nd August, 2020)
friend, 70F3239 supported by VVDI PROG. you can see the option in MCU menu.
also, if you can read by other programmer, VVDI2 bdm adapter should support too.in VVDI2 read this MCU the principle is same as programmer.
even you read by other programmer, there is one option in VVDI2 you can convert the data from different device
carbandit (5th November, 2018)
Hello Dear @Samic. Can you say does VVDI PROG 4.7.6 support 35160WT?+ read ID? Because in the instructions I saw that it supports, but only need M35160 adapter.
Thanks in advance
Eis w211 cls usa year about 09 10 nnot work. Tried few soft fersions few cables.
Mask identifies ok. But wont crack chip. Tested all conmections etc.
https://imgur.com/a/CXIf7Sr
Job finished with other tools.
lately all vvdi tool has many bugs.please pay atention and fix.because this cost very much time nerves and money from master pockets to recover cars when bricked
I'm trying to read a cas 4 with 1n35h mcu but my vvdi always say check connections and mcu and can't detect the id. Is the diagram on help correct??? Do I need to make the modifications on my 9s12 cable???
Enviado desde mi SM-G935F mediante Tapatalk
Hello anyone have pinout for read this cem module ???
NO PASS
Hello.
How to unlock PCF7937 ( GM key) with VVDI Prog ?
