Hi mates,
I´m triying to read 3M25J MCU on VAG body but give me this error. I tried with and without security.
Can anyone help me?
Thanks in advance
i have try to read kia picanto with fujistu
mb91f061b without succes.... i have try many pin out.. even with mcu cable v2 and v3
i always get device error and vvdi shut off.... my friend did a similar dash with a little difference in board without no problem
[2018-12-04 10:56:50] : Change to 2-MCU-->FUJITSU-MB9XF-->MB91F061
[2018-12-04 10:56:51] : Select <DFLASH>
[2018-12-04 10:56:56] : Check Device...
[2018-12-04 10:56:58] : 12V Power Adaptor unconnected
[2018-12-04 10:56:58] : Initialization device...
[2018-12-04 10:57:01] : Initialization success!
[2018-12-04 10:57:02] : Initialization chip...
[2018-12-04 10:57:03] : Device error
[2018-12-04 11:06:11] : Select <DFLASH>
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
Hi mates,
Can anyone help me?
Thanks in advance
SRS with 1L15Y unsecured
Hi mates,
I have this bcm from Seat Leon year 2007. Can we read this d76f0118 mcu?
Thanks in advance
mickye_dj (5th December, 2018)
Hi. The nec mcu to match donor one.
Can vvdi prog read it?
First time with this bcm.
alclot (6th December, 2018)
hie
please try to connect 12v power and test
Please check the file MC9S12_BAUDRATE.cfg
Have a FRM 2 61359159807 and I can not write a dump here because it always asks for Frequncy which is pulled from the file.
alclot (7th December, 2018)
Is VVDI prog safe for CAS 2? I have lost two CAS2 eeproms with it and it was not funny. In both cases though CAS seems to have been read with others before with unknown tools. Anyone know for certain?
It seems read ok if i write to CAS with it so maybe something else.
I already read and write 35160wt with vvdi prog and 35080 adapter, of course i only modified vin. I guess that it will be able to erase mileage. If erase incremental won't work, it's useless
+thanks if I helped you!
