bearheroes (23rd December, 2018), BradyAus (25th December, 2018), lalaina74 (24th December, 2018), mickye_dj (28th December, 2018)
I think mr. Arek ask Infineon tricore TC222/223
VVDI PROG latest software version V4.7.8 update
v4.7.8 (2018-12-21)
* This version DON't need update firmware
+ Add VVDI PROG USER MUNUAL 4.7.8 version in Doc folder
+ Add R5F100XXX_Data_4KB_Read, R5F100XXX_Data_4KB_Write, R5F100XXX_Data_8KB_Read, R5F100XXX_Data_8KB_Write, R5F100/101xEx_Flash_64KB_WRITE,
R5F100/101xEx_Flash_64KB_Read, R5F100/101xEx_Flash_64KB_Write, R5F100/101xAx_Flash_16KB_Read, R5F100/101xAx_Flash_16KB_Write, R5F100/101xCx_Flash_32KB_Write,
R5F100/101xCx_Flash_32KB_Read, R5F100/101xCx_Flash_48KB_Write, R5F100/101xCx_Flash_48KB_Read, R5F100/101xCx_Flash_96KB_Read, R5F100/101xCx_Flash_96KB_Write,
R5F100/101xCx_Flash_128KB_Read, R5F100/101xCx_Flash_128KB_Write, R5F100/101xCx_Flash_192KB_Write, R5F100/101xCx_Flash_192KB_Read, R5F100/101xCx_Flash_256KB_Read,
R5F100/101xCx_Flash_256KB_Write, R5F100/101xCx_Flash_384KB_Write, R5F100/101xCx_Flash_384KB_Read, R5F100/101xCx_Flash_512KB_Read,R5F100/101xCx_Flash_512KB_Write
options in <2-MCU>-><RENESAS-R5F>
+ Add MG3(2013) options in <5-DASHBOARD>-><SAICMOTOR>
+ Add WEIWANG-E50F(2018) options in <5-DASHBOARD>-><BAICMOTOR>
+ Add WEIWANG-S50 options in <5-DASHBOARD>-><BAICMOTOR>
+ Add AX7 options in <5-DASHBOARD>-><DONGFENG>
+ Add MONDEO(2017) options in <7-AIRBAG>-><FORD>
+ Add CIVIC(2016) options in <7-AIRBAG>-><HONDA>
+ Add SANTAFE-72 options in <7-AIRBAG>-><HYUNDAI>
+ Add MONDEO-AIR-CONTROLLER- MODULE(2007) option in <8-OTHER><VOLKSWAGEN>
Notes: pls keep using the latest version software, any problem post here or PM me.
alclot (24th December, 2018), damih (24th December, 2018), datapage (24th December, 2018), daxxer (24th December, 2018), Faraday (25th December, 2018), habbyb (26th December, 2018), keyantic (24th December, 2018), lidons (24th December, 2018), lion0304 (24th December, 2018), Maartinj (24th December, 2018), MobileTechGuy (24th December, 2018), PocketHero (25th December, 2018), polys123 (24th December, 2018), solitaire (24th December, 2018), taxo1965 (27th December, 2018), ThiagoArgentino (3rd January, 2019), trinicolin (25th December, 2018), vasiliev7719 (24th December, 2018), weza247 (28th December, 2018), zlatinou (24th December, 2018)
Dear samic can you reply to my post number 2731
https://www.digital-kaos.co.uk/forum...I-PROG/page183
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
It can read and write now with new 35160WT adapter.
Can you confirm that please does it erase and write 35160WT ?
Dear samic can You can add RH850 R7F701A223 RH850?
I read as R7F701A23, who can check the correct read?
Tariel (28th December, 2018)
Can the EEprom 160d0wt be deleted and written with VVDI prog?
hojo25 (29th December, 2018)
hello thanks for your reply
what do you mean by
Pins MD0 must be HI (Connect to VCC5) ( you mean that i need also to make bridge cable from md0 pin on mcu with vcc >?
Pins MD1,MD2 must be LO (Connect to GND) ( you mean that i need also to make bridge cable from md1 md2 pin on mcu with GND >?
Can vvdi prog make a spare key for Mercedes sprinter & Vito?
Sent from my SM-N960F using Tapatalk
